    another replacement request for help
    40 Posts 4 Posters 13.4k Views 1 Watching
    • Carlos J. Segnini R.C Offline
      Thanks again for your help.
      For some reason this time it isn’t working.
      I will try and fix it.
        Ekopalypse @Carlos J. Segnini R.
        @Carlos-J-Segnini-R
        Can you open the PythonScript console (plugin->PythonScript->Show Console) to see if there is an error?
        The replacement file has company and gas/oil tab separated, correct?
        Carlos J. Segnini R.C 1 Reply Last reply Reply Quote 0
          Carlos J. Segnini R. @Ekopalypse
          @Ekopalypse here is the log.
          I think it is because not all the wells need to be changed, so the first one in the file (Aery #B1H) does not appear in the second file, so the script is stopping. I will try leaving all wells, even those that doesnt need to be changed
          File “C:\Users\AppData\Roaming\Notepad++\plugins\Config\PythonScript\scripts\find_replace.py”, line 10, in <module>
          editor1.rereplace(search_for, replace_with)
          File “C:\Users\AppData\Roaming\Notepad++\plugins\Config\PythonScript\scripts\find_replace.py”, line 6, in replace_with
          return replacements[m.group(1)]
          KeyError: ‘Aery #B1H’
          And yes, the other file is separated by tabs.
          EkopalypseE 3 Replies Last reply Reply Quote 0
            @Carlos-J-Segnini-R
            Yes, that makes sense then we need to take another approach where we
            create the searches based on the second list. Gimme a minute
              @Carlos-J-Segnini-R
              from Npp import editor1, editor2
              replacements = dict(line.split('\t') for line in editor2.getText().splitlines() if line)
              def replace_with(m):
              # search_for = '(?<=<UWI>).+?(?=</UWI>)'
              for company in replacements.keys():
                  search_for = '<UWI>({})</UWI>\R\h*<WellType>\K.+?(?=</WellType>)'.format(company)
                @Carlos-J-Segnini-R
                depending on the file size a faster solution might be this
                    company = replacements.get(m.group(1), None)
                    if company:
                    else:
                        return m.group()
                search_for = '<UWI>(.+)</UWI>\R\h*<WellType>\K.+?(?=</WellType>)'
                Only scanning the text one time and in case the company found is
                not in the replacements dictionary we replace it with what was found.
                Btw. its midnight here - good night.
                  The first one worked!
                  Thanks so much for your help, I owe you a beer!
                  Have a good night
                    By the way, I went back and edited the script to run a second time looking for another instance below.
                    I’m sure there are better ways to jump three lines, but it’s late and I needed to finish. It worked! haha
                        search_for = '<UWI>({})</UWI>\R\h*.*\R\h*.*\R\h*.*\R\h*<PrimaryProduct>\K.+?(?=</PrimaryProduct>)'.format(company)
                      @Carlos-J-Segnini-R
                      In the end, what really counts is whether it does what it is supposed to do, right?
                      One, of several alternatives would be for example
                      <UWI>(.*)</UWI>(?s)(\R.+?)<PrimaryProduct>\K.+?(?=</PrimaryProduct>)
                      but whether this is better or worse depends on the real data.
                        Ekopalypse
                        @Ekopalypse said in another replacement request for help:
                        to be used in the script it would be
                        '<UWI>({})</UWI>(?s)(\R.+?)<PrimaryProduct>\K.+?(?=</PrimaryProduct>)'
                          Thanks @Ekopalypse I still owe you a beer
                          I’m sure i’ll come and ask questions again, so maybe more than a beer haha
                            Hi, @ekopalypse and All,
                            Just back from some holidays in Brittany ! Good day to everybody ;;-))
                            Looking back to your first script, of this discussion, it solves an interesting and general task :
                            • Given a first file, where some words / expressions must be replaced
                            • Given a second file containing all these the words / expressions and their corresponding replacements with a tabulation as a separator
                            This script executes, in the first file, all in once, the different replacements, from the second file’s table ;-))
                            Now, considering the slightly modified script, where the range of chars searched is contained in tags <TEST>......</TEST>
                                return replacements[m.group()]
                            editor1.rereplace('(?<=<TEST>).+?(?=</TEST>)', replace_with)
                            May I ask you about two questions :
                            • When the file to be modified ( new1 ) contains, in a tag <TEST>......</TEST>, a value not listed in the new 2 file, the scripts stops, no replacement occurs and the console message KeyError: 'ABCDE' is displayed
                            Example, with new 1 :
                            <Wellcollection>
                            	<Well replace="false">
                            		<TEST>BEFORE</TEST>
                            		<WellType>Oil</WellType>
                            		<ReserveStatusCollection>
                            		<TEST>And BEFORE</TEST>
                            		<TEST>ABCDE</TEST>
                            and new 2
                            BEFORE	After
                            And BEFORE	After
                            Could it be possible to avoid errors for all key values not listed in new 2 ?
                            • Secondly, how to ignore case of the key values ? I mean, instead of he obvious method, below, in new 2
                            BEFORE	After
                            And BEFORE	After
                            and before	After
                            I tried this version, without success :
                            import re
                            editor1.rereplace('(?<=<TEST>).+?(?=</TEST>)', replace_with, re.IGNORECASE)
                            with new 1 :
                            <Wellcollection>
                            		<TEST>BEFORE</TEST>
                            		<TEST>and before</TEST>
                            and new 2 :
                            BEFORE	After
                            And BEFORE	After
                            I still had the error :
                            KeyError: 'and before'
                            TIA,
                            Afterwards, I’ll do additional tests with your script and the regex S/R solution, below :
                            SEARCH (?is)(?<=<TEST>)(.+?)(?=</TEST>.+^---.+^\1\t(.+?)$)|^---.+
                            REPLACE ?1\2
                            This S/R executed against this text :
                            <Wellcollection>
                            		<TEST>BEFORE</TEST>
                            		<TEST>BEFORE</TEST>
                            BEFORE	After
                            And BEFORE	After 2
                            gives this changed text :
                            <Wellcollection>
                            		<TEST>After</TEST>
                            		<TEST>After 2</TEST>
                            		<TEST>After</TEST>
                            I bet that your script can manage largest files than my regex solution !
                              Ekopalypse @guy038
                              @guy038
                              thank you very much for checking the script.
                              A solution concerning missing replacements is to replace with what was
                              found or what I later suggested, creating unique search strings from the
                              list of replacements.
                              The first approach might work better for large files, the second seemed
                              more reasonable at this point.
                              To ignore case sensitivity - let’s changes the replacement keys to lower string
                              and check against lower matches but replace with defined replacement values. So a replacement dictionary would look like this
                                  replacements = {'täst': 'TEST'}
                              and would replace either Täst or täst with TEST always.
                              Let me think about it again.
                                Alan Kilborn @Ekopalypse
                                Not sure about the “later suggest” part, but this seems like a quick solution to the former:
                                    try:
                                        r = replacements[m.group()]
                                    except KeyError:
                                        r = m.group()
                                    return r
                                Disclaimer: I didn’t actually try it. :-)
                                  Ekopalypse @Alan Kilborn
                                  Yep, that is another solution as well.
                                    Hello @alan-kilborn, @ekopalypse and All,
                                    I’ve just tried your solution, Alan,and it worked like a charm ;-)) Clever : when an entry is missing in the dictionary, the script simply rewrites the key value
                                    So, if you realize that you forgot some entries in the new 2 file, ( so some replacements ! ), the easy workaround is :
                                    • Add all these new entries as well as their corresponding replacement parts
                                    • Re-run the script
                                    Now regarding the case’s problem, we may run a regex S/R to get an unique case of an expression, before running the script
                                    For instance, instead of defining, in new 2, these 5: entries
                                    BEFORE	After
                                    Before	After
                                    before	After
                                    BEFore	After
                                    befORE	After
                                    • Firstly, we would use the regex S/R, against our text in new 1 :
                                      • SEARCH (?i)Before
                                      • REPLACE \U$0
                                    • Secondly, we would re-run the Python script, with only 1 entry, in new 2 :
                                    BEFORE	After
                                    Best Regards
                                      Alan Kilborn @guy038
                                      @guy038 said in another replacement request for help:
                                      Yes, I didn’t see a quick mod to the original script, and I didn’t want to alter its “simple elegance” to hack in casing support. Of course, it’s possible to do, but the original was such a work of art… :-)
                                        Hi, @alan-kilborn, @ekopalypse and All,
                                        Like @ekopalypse, I must had been tired, yesterday, while posting !
                                        Regarding the case’s problem, no need to re-run the script : Just run the following S/R, of course :
                                        • SEARCH (?i)Before
                                        • REPLACE After
                                        So, for all the remaining expressions which must be replaced, whatever their case, better to use the general regex :
                                        • SEARCH (?i)(Expression_1)|(Expression_2)|(Expression_3)....
                                        • REPLACE (?1Replacement_1)(?2Replacement_2)(?3Replacement_3)...
                                        BR
                                          Hello, @ekopalypse and All,
                                          After tests, I confirmed that any kind of regex, like below :
                                          REPLACE ?1\2
                                          does not work properly ( 1 all contents match ! ) as soon as the scanned file contains more than 200 lines about :-(
                                          Whereas your Python script, with the @alan-kilborn’s modification, works nice !
                                          Given the initial XML file, below, in new 1 tab :
                                          <Wellcollection>
                                          		<TEST>BEFORE</TEST>
                                          		<ReserveStatusCollection/>
                                          		<TEST>Guy</TEST>
                                          		<TEST>00000</TEST>
                                          		<TEST>00001</TEST>
                                          		<TEST>00002</TEST>
                                          		<TEST>99998</TEST>
                                          		<TEST>99999</TEST>
                                          		<TEST>BEFORE</TEST>
                                          		<TEST>Guy</TEST>
                                          	</Well>
                                          </Wellcollection>
                                          and the new_2 contents, in secondary view :
                                          BEFORE	After
                                          Guy	Guy038
                                          and the python script :
                                              try:
                                              except KeyError:
                                                  r = m.group()
                                              return r
                                          => On my old Win XP laptop, it took 26s to execute :
                                          • 100,000 identical replacements ( from 00000 to 99999 as not in the dictionary )
                                          • 2 replacements from BEFORE to After
                                          • 2 replacements from Guy to Guy038
                                          So, a script solution is definitively the right solution to adopt to solve this general task !
                                          Best regards
                                          However, in my example, it would be valuable to find out a method to avoid all these identical replacements ;-))
                                            Hello friends
                                            So one year later I had to do the same replacements, and found that the original script did not work anymore (Same error as reported by @guy038 ). Something must have changed in Notepad++, Python or somewhere else, because the first time it worked fine.
                                            Anyway, I updated the code as suggested by @Alan-Kilborn and it worked correctly.
                                            Cheers everyone
                                            • guy038G guy038 referenced this topic on
