    Notepad++ crashes when double pane is open and f12 is pressed
    2 Posts 2 Posters 574 Views
    • jamminjamesJ Offline
      jamminjames
      If I have a double pane open (I’ve hit “Move to other view”) and hit f12, Notepad++ crashes every time. If only one window is open, it does not, it goes into the special view that it’s supposed to.
      It always recovers just fine, and goes right back to where it was, with the last thing I typed there. However, it’s quite annoying.
      I’m on a Windows 7 machine (I know, I know), and Notepad++ is up to date.
      I’m not sure of the best place to report a bug like this. Please let me know if I should post somewhere else about it.
        Ekopalypse @jamminjames
        @jamminjames
        works for me.
        Did you try to start without any plugins loaded?
