    How to make cursor larger ?
    9 Posts 6 Posters 7.2k Views 1 Watching
    • vmars vernonV Offline
      vmars vernon
      Tia;
      Having trouble seeing the cursor .
        PeterJones @vmars vernon
        @vmars-vernon
        Settings > Prefernces > Editing > Caret Settings > Width (pulldown selector).
        cf: https://npp-user-manual.org/docs/preferences/#editing
          vmars vernon
          Thanks Peter;
          Found this too:
          [link text] https://community.notepad-plus-plus.org/topic/13231/make-cursor-more-visible?_=1605289939836 (link url)
          • ? Offline
            A Former User
            I wonder if it’s possible to change caret’s height? (couldn’t find )
            • Alan KilbornA Online
              Alan Kilborn @Guest
              @Victorel-Petrovich said in How to make cursor larger ?:
              No. Does this lack of such flexibility really bother you, or are you just wondering … ?
              ? J 2 Replies Last reply Reply Quote 1
              • ? Offline
                A Former User @Alan Kilborn
                • jessica brownJ Offline
                  jessica brown
                  1 Reply Last reply Reply Quote -2
                  • J Offline
                    julianop @Alan Kilborn
                    @Victorel-Petrovich: I, for one, would very much like the option of a more “significant” cursor (I don’t know why it’s called a “caret” in NP++: that’s the name given to the little top hat accessed by shift-6 on the US keyboard): my eyes aren’t what they used to be, and even with a three pixel vertical line and a fast flash it sometimes takes a moment or two to find the cursor.
                      PeterJones @julianop
                      @julianop said in How to make cursor larger ?:
                      … : my eyes aren’t what they used to be, and even with a three pixel vertical line and a fast flash it sometimes takes a moment or two to find the cursor.
                      Settings > Preferences > Editing 1 > Caret Settings allows up to 3 pixels wide for the “vertical line” version… if that’s not enough on its own, then Settings > Style Configurator > Language: Global Styles > Style: Caret colour and … > Style: Multi-edit carets color allows you to change the color for the caret (for normal or multi-edit mode) to make it even more obvious to your eyes. And if that’s still not enough, the Caret Settings allow Block or Block after options, which make it a full character wide, rather than being limited to 3 pixels.
                      Notepad++ uses this alternate term “caret” to indicate the text insertion point, to disambiguate it from the “cursor” which almost always refers to the “mouse cursor” in modern GUIs when used without a disambiguation prefix. Calling it “caret” is easier than saying “text cursor” throughout the GUI and User Manual, and follows computing terminology that’s been around for decades.
