    A little help please
    6 Posts 3 Posters 970 Views 1 Watching
    • Kathy MedinaK Offline
      Kathy Medina
      Im using notepad to try something
      i have a lot of trext like this:
      <host endtime=“1610639975”><address addr=“179.8.138.90” addrtype=“ipv4”/><ports><port protocol=“tcp” portid=“37777”><state state=“open” reason=“syn-ack” reason_ttl=“60”/></port></ports></host>
      <host endtime=“1610639976”><address addr=“201.217.248.199” addrtype=“ipv4”/><ports><port protocol=“tcp” portid=“37777”><state state=“open” reason=“syn-ack” reason_ttl=“52”/></port></ports></host>
      <host endtime=“1610639977”><address addr=“190.82.98.90” addrtype=“ipv4”/><ports><port protocol=“tcp” portid=“37777”><state state=“open” reason=“syn-ack” reason_ttl=“56”/></port></ports></host>
      <host endtime=“1610639977”><address addr=“201.217.253.232” addrtype=“ipv4”/><ports><port protocol=“tcp” portid=“37777”><state state=“open” reason=“syn-ack” reason_ttl=“54”/></port></ports></host>
      and i need to delete everything and just leave the ips
      like this:
      179.8.138.90
      201.217.248.199
      190.82.98.90
      201.217.253.232
      im a newbi on this, and im trying to do this with the “replace” option.
      thanks friends!
      Alan KilbornA astrosofistaA 2 Replies Last reply Reply Quote 0
        Alan Kilborn @Kathy Medina
        @Kathy-Medina
        I’m sure there are “tighter” ways to match IP addresses, but I’d probably do this with your data:
        Open the Mark dialog by pressing Ctrl+m
        find: \d{1,3}(?:\.\d{1,3}){3}
        search mode: regular expression
        Press the Mark all button.
        This should mark in a color (usually reddish) your IPs.
        Press the Copy Marked Text button and then do a paste somewhere else. There’s your data.
        • astrosofistaA Offline
          astrosofista @Kathy Medina
          Hi @Kathy-Medina
          I assume that the curly quotes in the data you posted are actually straight quotes. If that is the case, then the following regex will do the job:
          Search: (?-s).*?addr="([\d.]+)".*?|.*
          Replace: $1
          Put the caret at the very beginning of the document, select just the Regular Expressions mode and click the Replace All button.
          Take care and have fun!
            Kathy Medina
            @astrosofista said in A little help please:
            $1
            great!
            thanks a lot
            the replace method works for me.
            About the Alans Method, a can t find the option “copy marked text”
              @Kathy-Medina said in A little help please:
              copy marked text
              You’re welcome. To take advantage of the “copy marked text” option you need v7.9.1.
                Alan Kilborn @astrosofista
                …or later!
