    Replace all occurrences of a character between 2 words
    22 Posts 5 Posters 6.1k Views 1 Watching
    • prahladmifourP Offline
      prahladmifour
      Hello,@vamshi-reddy-0
      Please try this code, To Replace all occurrences of a character between 2 words.
      RegEx:
      /(?:\G(?!^)|string1)(?:(?!string1|string2).)*?\K\h(?=.*string2)/gm
      I hope this RegEx will be useful to you.
      Thank you.
      • Alan KilbornA Online
        Alan Kilborn @guy038
        @guy038 said in Replace all occurrences of a character between 2 words:
        Indeed, as meta-characters, the [ and ] must be escaped with the \ symbol to search them as literal symbols. But the [ syntax has also a special meaning, with the NodeBB Markdown language !
        Given these problems (that we usually initially forget when posting), I may consider going with this substitution instead, for any future regexes I post containing the dreaded backslash-bracket situation:
        for backslash-open-square-bracket: \x5B
        for backslash-close-square-bracket: \x5D
        Or…maybe not. :-)
