    Help with Replace
    2 Posts 2 Posters 499 Views 1 Watching
    • Otto SchoO Offline
      Otto Scho
      Dear Community,
      I need to Do the following in Notepad:
      I want to use the Replace to delete everything after FOG
      TO: ( ARGF41)
      how can I do such things?
      It is just like in Excel: Replace FOG* with empty.
      Thank you in Advance
      Toti
        Ekopalypse @Otto Scho
        @Otto-Scho
        In the search dialogue, check the regular expression checkbox and use the following search term FOG.+?\b to replace it with an empty string.
