    Layout breaks after a few days
    28 Posts 8 Posters 14.3k Views 2 Watching
      PeterJones @FlorianSchaetz
      @FlorianSchaetz ,
      In my experience, video drivers don’t always update automatically, even when you have automatic updates on… For that, it’s often good to check your video card manufacturer website directly.
      FlorianSchaetzF 1 Reply Last reply Reply Quote 0
      • FlorianSchaetzF Offline
        FlorianSchaetz @PeterJones
        @PeterJones Yeah, but as I said, they are current, no update available.
          @FlorianSchaetz ,
          Well, it was worth a try.
          It seems to be @Madzilla’s experience that uninstalling the recent Microsoft Windows update (as mentioned above) will fix the problem – maybe you could uninstall that Windows update, at least until a permanent fix is found.
          If you are unable or unwilling to uninstall that update, then maybe you could use Run As Administrator mode, which in other of the discussions has anecdotally gotten around this display bug caused by the Windows update. Or maybe run a portable version.
          Other than that, I’m out of suggestions.
              FlorianSchaetz
              @PeterJones Personally, I will simply switch to code, at least for now, because I don’t like the thought of uninstalling security updates nor of enabling admin privileges for an app. (And please don’t get me wrong, this is not an angry “taking-my-toys-and-leaving-the-playground” thing, but simply the most easy workaround for me. As soon as it works again, I plan on going back the Notepad++, since I’m old and do not like new things anyway ;-)
              • Maximilian LaurenzM Offline
                Maximilian Laurenz
                I got the same problem out of nothing today. EDIT: Running Notepad++ as administrator seems to fix it.
                • Chris WatsonC Offline
                  Chris Watson
                  Opened NotePad++ today to find this issue. After googling, cam to this page I can confirm that my device has not changed for 9 months and suddenly this happens after updating NP++
                  • Alan KilbornA Online
                    Alan Kilborn @Chris Watson
                    @chris-watson
                    See HERE.
