    Search for character classes but not replace them
    51 Posts 8 Posters 21.2k Views 4 Watching
      Hi, @alan-kilborn, @mkupper and All,
      Ah…, indeed, the (?s). regex seems to give incoherent results and the total number of hits is erroneous, too :-(( However, note that the Count operation remains correct !
      But, luckily, the [[:unicode:]] regex does work nicely !
      Thus, I extended your example to three other characters which lie in the [\x00-\xFF] range, so this string : Aé💙☀🡢⮃🠧🠉…👍👌👎. And, if we use the [\x00-\xFF]|[[:unicode:]] regex, it correctly matches 13 characters, as shown in the snapshot below :
      Regarding my macro, I’m going to ask Don Ho to add a C++ equivalent ! A nice improvement would be to analyse the Search and Replace fields and modify all the \x{#####} regex syntaxes with their surrogate equivalents \x{D###}\x{D###} for correct searches and replacements in all circonstances. what’s your feeling about it ?
      BR
      Alan KilbornA CoisesC 2 Replies Last reply Reply Quote 2
        Alan Kilborn @guy038
        It doesn’t sound like something Don Ho would be interested in, but…go for it.
        • mkupperM Offline
          mkupper @guy038
          @guy038 said in Search for character classes but not replace them:
          If anyone is interested by this file, I could send it by e-mail. Just tell me !
          Is this the same Total_Chars.txt that you uploaded to a Google drive as part of this forum post?
          • mkupperM Offline
            mkupper @Alan Kilborn
            @Alan-Kilborn said in Search for character classes but not replace them:
            If I do a Find All in Current Document, it yields 11 hits, but I only see 3 characters highlighted as matches:
            The three you see are “☀⮃…” which can be searched using \x{2600}, \x{2B83}, and \x{2026}. All three are Basic Multilingual Plane (BMP) characters.
            The other 7 characters, or “💙🡢🠧🠉👍👌👎”, are all extended Unicode. Here’s how to search for them using surrogate pairs:
            • 💙 U+1F499 \x{D83D}\x{DC99}
            • 🡢 U+1F862 \x{D83E}\x{DC62}
            • 🠧 U+1F827 \x{D83E}\x{DC27}
            • 🠉 U+1F809 \x{D83E}\x{DC09}
            • 👍 U+1F44D \x{D83D}\x{DC4D}
            • 👌 U+1F44C \x{D83D}\x{DC4C}
            • 👎 U+1F44E \x{D83D}\x{DC4E}
            While Notepad++ and Scintilla seem to store text as UTF-8 the search function has the appearance of converting what we search for into UTF-16 strings and seems to convert the text from UTF-8 into UTF-16 on the fly when searching it. This seems like a lot of overhead. I have never dug hard into what happens under the hood. My guess is that the search computes the surrogate pairs and then extracts the lower 10 bits from each word and spreads the 20 bits out into where they would appear in UTF-8 encoded data. I think that would work and be fast for scanning UTF-8 encoded data.
              Coises @guy038
              I can add this note, for what (if anything) it’s worth.
              At some point in the development of Columns++, I realized that to get around some limitations in the Scintilla search interface I’d need to use Boost Regex directly. I really wanted, as part of that, to handle Unicode properly, as Unicode characters instead of as UTF-16 bytes. Boost Regex includes support for Unicode, but to do that it depends on ICU.
              I could not figure out how to include the necessary dependencies (whatever they are) from ICU as part of a DLL compilation. All instructions discussed installing it at the operating system level. I didn’t want to tell users they had to install something separate system-wide. I gave up on that approach.
              So then I thought I could at least write a proper iterator for UTF-32 instead of wchar_t. And ran into character traits. I thought seriously of trying to leverage the traits for wchar_t and “guess” at what to do outside the BMP. (Looking into this made it clear why Boost relies on ICU instead of doing it themselves.) I eventually gave up and implemented UTF-16/wchar_t, essentially what Notepad++ does. It works reasonably well with Windows (which is also UTF-16 as wchar_t) when searching for specific character sequences and/or working with characters in the BMP.
              Full and proper Unicode support, as best I can figure out, involves a large amount of detail, which is continuously being updated. (For those who don’t know: not every Unicode character is a single Unicode code point. And unlike the UTF-8/16/32 relationship, there’s no fixed algorithm to tell you which code points combine with others. Then there’s knowing what’s a capital letter, what’s a lower case letter, which letters are equal when case ignored… none of it follows a formula.) If there’s a more compact, contained implementation than ICU, that would be great, but I couldn’t find one. (The C++ standards committee has punted and deprecated the little bit of Unicode support C++ ever had. There are types defined, but nothing that does anything useful with them.)
              I did, however, discover after reading this thread that my search doesn’t handle [[:unicode:]] the way Notepad++ does. There must be something clever hidden in the Notepad++ implementation that I missed which lets it “understand” characters outside the basic multilingual plane.
                Alan Kilborn @mkupper
                @mkupper said:
                which can be searched using…
                Clearly you see why this isn’t a good answer to the original query?
                I don’t want to search specifically, I want to search generically.
                I started with (?s). as the simplest thing from this thread, as it was stated earlier that it “works”.
                I showed (using some specific characters) that this generic search didn’t work.
                Sure, I can try [[:unicode:]] for what I’m trying to do, and see what else – problemwise – I run into.
                • mkupperM Offline
                  I did an experiment with searching for [[:unicode:]] on @guy038’s Total_Chars.txt file and learned the following:
                  • It does not match \x{0000} to \x{00FF}
                  • It matches \x{0100} to \x{0177}
                  • It does not match Ÿ which is \x{0178}
                  • It matches \x{0179} to \x{FFFF}
                  Starting at U+10000 it gets weird. I made a UTF-8 encoded test file that has 78343 lines where each line starts with a Unicode character starting at U+10000 and running up to U+10FFFF. Each character is followed by a tab and then notes about the character. For example line 15125 has:
                  🌵		U+1F335		\x{D83C}\x{DF35}	\xF0\x9F\x8C\xB5
                  It lets me know the Unicode code point, the surrogate pairs, and the UTF-8 encoding for that character.
                  • A count for [[:unicode:]] says 78343 which is the number of lines.
                  • A search for ^[[:unicode:]] or \R[[:unicode:]] gets zero hits.
                  • A search for [[:unicode:]]\t gets 78343 hits.
                  It seems that [[:unicode:]] is matching the second word of the surrogate pair but not the first. The first word of the pairs ranges from \x{D800} to \x{DBFF} while the second word is always in the range \x{DC00} to \x{DFFF}. The weird thing is that [[:unicode:]] matches orphan words in the range \x{D800} to \x{DBFF} and also matches orphans in the range \x{DC00} to \x{DFFF}. It’s possible that Notepad++ does something special with those orphans as you not supposed to have them as orphans plus there are intentional gaps in the UTF-8 encoding system so they can’t be encoded as UTF-8 … if you follow the rules.
                    Hello, @alan-kilborn, @mkupper, @coises and All,
                    First, @mkupper, you made the same mistake that I did when we spoke about the LS and PS characters and for which you had given me the solution !
                    • Indeed, the regex (?i)[[:unicode:]] does not match the \x{0178} character
                    • Luckily, the regexes (?-i)[[:unicode:]], even (?s-i)[[:unicode:]], do match the \x{0178} character as well as any character over \x{00FF}
                    Oh…, My God : regarding the Total_Chars.txt file, I’m really confused because I’ve completely forgotten that this file was accessible, among some others, on my google drive account ! So, for people interested, simply click on the link below :
                    https://drive.google.com/file/d/1kYtbIGPRLdypY7hNMI-vAJXoE7ilRMOC/view?usp=sharing
                    As a security, once the Total_Chars.txt file loaded in Notepad++, you can right-click on its tab and choose the Read-Only option
                    Thank you, @mkupper, for refreshing my memory ;-))
                    Best Regards
                    mkupperM 1 Reply Last reply Reply Quote 2
                      Coises @mkupper
                      @mkupper said in Search for character classes but not replace them:
                      I’ve been making attempts to follow this under debug in Visual Studio, but so far… I’m lost in the murky depths of Boost regex.
                      The iterator for UTF-8 documents is implemented in these files:
                      UTF8DocumentIterator.h
                      UTF8DocumentIterator.cxx
                      and you can see here how UTF-8 sequences are mapped to wchar_t/UTF-16.
                      But why . matches one of a surrogate pair but [[:unicode:]] matches both escapes me. (In my search in Columns++ both only match a single wchar_t. I don’t use the same iterator code, but I don’t know what I do that would produce different results, other than handling invalid UTF-8 differently.)
                      To make sense of invalid UTF-16, we’d have to look at the process by which Notepad++ loads UTF-16 and transforms it into UTF-8. I think there is some method of encoding wchar_t sequences that don’t represent valid UTF-16 as invalid, but still round-trip-able, UTF-8.
                      If you uncover a clue, I would welcome one.
                      mkupperM Mark OlsonM 2 Replies Last reply Reply Quote 2
                      • mkupperM Offline
                        mkupper @guy038
                        (?-i)[[:unicode:]]
                        Thank you for doing that test as I was thinking about doing something similar. I had seen that Ÿ - \x{0178} was the upper case form of ÿ - \x{00FF} and wondered if the failure to match was a one-off edge error. The failure to match still seems like a bug to me unless the rule for (?-i)[[:unicode:]] is that it only matches if both the upper and lower case form of a letter has a character code of \x0100 or higher. FWIW, Notepad++'s convert case functions work on ÿŸ.
                        I did a search for other letters where the one letter case was \x0000 to \x00FF and the other was \x100 or higher and found
                        ß	\x{00DF}	\xC3\x9F		LATIN SMALL   LETTER SHARP S
                        ẞ	\x{1E9E}	\xE1\xBA\x9E	LATIN CAPITAL LETTER SHARP S
                        (?i)[[:unicode:]] matches ẞ (U+1E9E) as expected. However, I also see that Notepad++'s case conversion functions fail to convert that letter to its upper or lower case version. A search using (?-i)ß or (?-i)ẞ also fails match both cases of that letter. According to U+00DF and U+1E9E on fileformat​.​info that pair should be case-convertible.
                        • mkupperM Offline
                          mkupper @Coises
                          @Coises, The UTF8DocumentIterator code seems straightforward and does more or less mindless conversion. It barely cares about invalid codes, etc. The logic silently allows overlong encoding where for example, a 3-byte UTF sequence is used to encode a value from 0x00 to 0x7F which is normally a 1 byte sequence or 0x0080 to 0x07FF which is normally a 2 byte sequence
                          The logic also silently allows 4-byte UTF-8 sequences that encode 0x110000 to 0x1FFFFF which is beyond the range assigned to Unicode. It will attempt to convert those values into surrogate pairs. The first word of the pair will overflow the 0xD800 to 0xDBFF range assigned to the first word. The second word is ok and will be a value in the range 0xDC00 to 0xDFFF which is correct for the second word of the pair. I’d have to trace a bit more carefully but the code also seems to silently allow for 5 and 6 byte long encodings that either contain underlong values or will overflow the first word of the surrogate pairs. Overall, it’s not a huge issue that results in garbage in, garbage out, but it should not crash the editor unless something is unhappy about orphan parts of surrogate pairs.
                          I’m now wondering if the internal storage is UTF-16. That would explain some of the search behavior.
                          • Mark OlsonM Offline
                            Mark Olson @Coises
                            @Coises said in Search for character classes but not replace them:
                            This reminds me of an issue where (IIRC; don’t have a computer with Notepad++ on it in front of me right now) you get weird things like .* matching any number of emojis, but (.)* does not match any emojis at all.
                              Coises @mkupper
                              That part I can tell you with certainty, because the search I implemented in Columns++ accesses the Scintilla buffer directly using SCI_GETRANGEPOINTER.
                              Scintilla’s storage for document text is either “ANSI” (current system code page) or UTF-8. However, the character type template parameter for boost::regex search in UTF-8 documents is wchar_t because of the problems I mentioned earlier. (I think part of this is that the std::char_traits specialization on Windows for wchar_t is apt for UTF-16. In any case, boost::regex can handle wchar_t reasonably by itself, but something else — either ICU or a std::char_traits specialization — would be needed to handle 32-bit Unicode.) So a custom iterator is needed to translate the UTF-8 bytes into wchar_t holding UTF-16.
                              Notepad++ and Columns++ both do that translation, though we go about it in somewhat different ways.
                              I still haven’t figured out how [[:unicode:]], being a character class which should always match either nothing or a single “character” in the regex sense of character, manages to match a surrogate pair in Notepad++.
                              mkupperM 1 Reply Last reply Reply Quote 1
                              • mkupperM Offline
                                mkupper @Coises
                                I don’t think [[:unicode:]] matches surrogate pairs. It seems to match the second word of the pair but not the first. Let’s say we have tab🌵tab on a line
                                • The cactus is U+1F335 and we normally use the surrogate pair \x{D83C}\x{DF35} to search for it.
                                • \x{D83C} reports a zero length match
                                • \x{DF35} selects the cactus and seems to select all of the encoded data for the cactus.
                                • \t\x{D83C} selects the leading tab but not the cactus. You can verify this by pressing Del and the tab goes away but the cactus remains.
                                • \x{DF35}\t selects the cactus and the trailing tab. It seems to be including both words in the selection as I can copy/paste it and get the cactus+tab.
                                • \t[[:unicode:]] says it can’t find the text.
                                • [[:unicode:]]\t selects the cactus and the trailing tab.
                                • \x{D83C}[[:unicode:]]\t selects the cactus and the trailing tab.
                                • [[:unicode:]][[:unicode:]]\t says it can’t find the text.
                                • \t.\t says it can’t find the text.
                                • \t..\t selects the tab+cactus+tab.
                                It seems that [[:unicode:]] matches the second word. I suspect this was done so that you don’t need to use [[:unicode:]][[:unicode:]] the way you need to use dot-dot to match these characters.
                                I did a search/replace using [[:unicode:]]\t with \x{DF36}\t. The cactus changes into an empty box. I was hoping to see a 🌶 hot pepper by swapping out the second word. The UTF-8 data is 09 f3 9d a0 89 meaning the leading tab is still there but the trailing tab is gone and it’s a hot mess as that that last 89 is a continuation byte that holds a tab.
                                  All,
                                  It’s really good discussion going on here. I’m listening. :-)
                                  Meanwhile I’m getting discouraged that, with the tools available to me, I’m not going to be able to do the task I set out to do. I haven’t provided details on that, but it should be clear by now that I want an expression to match any single UTF-8 “character”. Maybe I’m being silly because perhaps that isn’t a solid concept. :-(
                                    @alan-kilborn, @mkupper, @coises, @mark-olson and All,
                                    As promised, here is my feature request :
                                    https://github.com/notepad-plus-plus/notepad-plus-plus/issues/16153
                                    Best Regards
                                    • mkupperM Offline
                                      mkupper @guy038
                                      While you mentioned \x{0001F600} in the introduction I noticed that the the macro won’t transform it into a surrogate pair. Maybe you’d want to first normalize the value:
                                      Search: (?-i)(?<=\\x\{)0+(?i)(?=(?:[1-9A-F]|10)[[:xdigit:]]{4}\})
                                      Replace: (nothing)
                                      It’s possible you could add that to your first S/R which appends the \x1F and then would not need to test for a trailing \} in your later S/R.
                                        Hello, @alan-kilborn, @mkupper, @coises, @mark-olson and All,
                                        Thanks @mkupper for your observation. I first did not thought about possible leading zeros. So, I improved my macro to this version, which, I hope, will be the last one !
                                                <Macro name="Surrogates Pairs in Selection" Ctrl="no" Alt="no" Shift="no" Key="0">
                                                    <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?-i)\\x\{0*((?:10|[[:xdigit:]])[[:xdigit:]]{4})(?=\})" />
                                                    <Action type="3" message="1625" wParam="0" lParam="2" sParam="" />
                                                    <Action type="3" message="1602" wParam="0" lParam="0" sParam="\\x{$1\x1F" />
                                                    <Action type="3" message="1702" wParam="0" lParam="640" sParam="" />
                                                    <Action type="3" message="1701" wParam="0" lParam="1609" sParam="" />
                                                    <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?i)(?:(1)|(2)|(3)|(4)|(5)|(6)|(7)|(8)|(9)|(A)|(B)|(C)|(D)|(E)|(F)|(10))(?=[[:xdigit:]]{4}\x1F\})|(?:(0)|(1)|(2)|(3)|(4)|(5)|(6)|(7)|(8)|(9)|(A)|(B)|(C)|(D)|(E)|(F))(?=[[:xdigit:]]{0,3}\x1F\})" />
                                                    <Action type="3" message="1602" wParam="0" lParam="0" sParam="(?{1}0000)(?{2}0001)(?{3}0010)(?{4}0011)(?{5}0100)(?{6}0101)(?{7}0110)(?{8}0111)(?{9}1000)(?{10}1001)(?{11}1010)(?{12}1011)(?{13}1100)(?{14}1101)(?{15}1110)(?{16}1111)(?{17}0000)(?{18}0001)(?{19}0010)(?{20}0011)(?{21}0100)(?{22}0101)(?{23}0110)(?{24}0111)(?{25}1000)(?{26}1001)(?{27}1010)(?{28}1011)(?{29}1100)(?{30}1101)(?{31}1110)(?{32}1111)" />
                                                    <Action type="3" message="1601" wParam="0" lParam="0" sParam="([01]{10})([01]{10})(?=\x1F)" />
                                                    <Action type="3" message="1602" wParam="0" lParam="0" sParam="110110\1\x1F}\\x{110111\2" />
                                                    <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?:(0000)|(0001)|(0010)|(0011)|(0100)|(0101)|(0110)|(0111)|(1000)|(1001)|(1010)|(1011)|(1100)|(1101)|(1110)|(1111))(?=[[:xdigit:]]*\x1F\})|\x1F" />
                                                    <Action type="3" message="1602" wParam="0" lParam="0" sParam="(?{1}0)(?{2}1)(?{3}2)(?{4}3)(?{5}4)(?{6}5)(?{7}6)(?{8}7)(?{9}8)(?{10}9)(?11A)(?12B)(?13C)(?14D)(?15E)(?16F)" />
                                                </Macro>
                                        As a test :
                                        • Select all the text below :
                                        \x0f
                                        \xff
                                        \x{0f}
                                        \x{ff}
                                        \x{000f}
                                        \x{00ff}
                                        \x{0fff}
                                        \x{ffff}
                                        \x{10000}
                                        \x{010000}
                                        \x{0010000}
                                        \x{00010000}
                                        \x{1f600}
                                        \x{01f600}
                                        \x{001f600}
                                        \x{0001f600}
                                        \x{10ffff}
                                        \x{010ffff}
                                        \x{0010ffff}
                                        \x{110000}
                                        \x{1fffff}
                                        • Run once the Surrogate pairs in selection macro
                                        You should get the expected text, below :
                                        \x0f
                                        \xff
                                        \x{0f}
                                        \x{ff}
                                        \x{000f}
                                        \x{00ff}
                                        \x{0fff}
                                        \x{ffff}
                                        \x{D800}\x{DC00}
                                        \x{D800}\x{DC00}
                                        \x{D800}\x{DC00}
                                        \x{D800}\x{DC00}
                                        \x{D83D}\x{DE00}
                                        \x{D83D}\x{DE00}
                                        \x{D83D}\x{DE00}
                                        \x{D83D}\x{DE00}
                                        \x{DBFF}\x{DFFF}
                                        \x{DBFF}\x{DFFF}
                                        \x{DBFF}\x{DFFF}
                                        \x{110000}
                                        \x{1fffff}
                                        As you can see, values under \x{FFFF} are not changed and the last \x{110000} and \x{1fffff} code-points are not considered too, as not Unicode characters at all !
                                        • mkupperM Offline
                                          mkupper @guy038
                                          @guy038 Your first expression allows \x{0ffff} and the remaining expressions end up mangling that into \x{7FFF1}. That is why I had used (?:[1-9A-F]|10) earlier as I knew I could not and should not attempt to translate BMP code points into surrogate pairs.
                                          At the time I wrote (?:[1-9A-F]|10) I wondered if (?:10|[1-9A-F]) was better and would result in less backtracking for common values. Mental gymnastics in the shower lead to that (?:10|[1-9A-F]) was better but I then forgot about it and did not do any testing to see how common it was for Unicode code points values to start with 10. I noticed you used (?:10|[[:xdigit:]]) but don’t know if that was based on testing, experience, or habit.
                                            Coises @Alan Kilborn
                                            It’s not unreasonable. The concept of a Unicode code point is well-defined, and the UTF-8 representation of a code point is well-defined.
                                            The “character” problem arises with combining marks and variant forms. If you assume normalization to composed form, most characters are single code points. I suspect you would be content with an expression which matched any character represented by the UTF-8 sequence for a single Unicode code point. (That includes all the ones in your example.)
                                            I’m still trying to make sense of what happens. I found an error in my Columns++ code which prevents me (until I publish a fix) from demonstrating this, but what you want is theoretically possible (with the caveat above about code points vs characters) with the expression [\x{d800}-\x{dbff}]?[^\x{d800}-\x{dbff}]. If you try that by itself, it looks like it works in Notepad++; but if you try putting anything else to match in front of it, it fails. The match with a low surrogate never happens, while the high surrogate match visibly selects the whole character, but internally matches only the second half of the surrogate pair.
