    Search for character classes but not replace them
    51 Posts 8 Posters 19.2k Views 4 Watching
      Coises @Alan Kilborn
      @Alan-Kilborn said in Search for character classes but not replace them:
      I haven’t provided details on that, but it should be clear by now that I want an expression to match any single UTF-8 “character”. Maybe I’m being silly because perhaps that isn’t a solid concept. :-(
      By the way… based on something I found while working on finding a better way to do this… I think that you’ll find the regex search in PythonScript doesn’t have this problem. I believe a period there will just match one character of any sort. (I haven’t tried it because I don’t know Python… I base my statement on the support code, which has given me an idea for how to make similar improvements to the search in Columns++.) I think you’ll also be able to use actual Unicode values above 0xffff rather than needing to split them into surrogates.
        Alan Kilborn @Coises
        @Coises said:
        …given me an idea for how to make similar improvements to the search in Columns++.
        I believe that you are talking about what you said HERE.
        It appears to be true; see code below.
        This does NOT appear to be true; see code below.
        The aforementioned code (note that it is Python3):
        from Npp import *
        # 💙<-- we'll be searching for the blue heart character
        print('using character:', editor.findText(FINDOPTION.REGEXP, 0, editor.getLength(), '💙'))
        print('using surrogate pairs:', editor.findText(FINDOPTION.REGEXP, 0, editor.getLength(), r'\x{D83D}\x{DC99}'))
        print('using codepoint above FFFF:', editor.findText(FINDOPTION.REGEXP, 0, editor.getLength(), r'\x{1F499}'))
        print('using .:', editor.findText(FINDOPTION.REGEXP, 0, editor.getLength(), r'.(?=<--)'))
        and results when running it:
        using character: (21, 25)
        using surrogate pairs: (21, 25)
        using codepoint above FFFF: (-2, 7)
        using .: (21, 25)
        The -2 returned for the first position of the range match is a indication of “invalid regular expression”. The other results, (21,25), are correct for the position range of the character being searched for – it’s a character with 4-byte encoding.
          Coises
          @Alan-Kilborn @Ekopalypse @guy038 @mkupper
          If anyone is curious, an experimental version of Columns++ in which regular expressions process each Unicode code point as a single regex character is available here:
          https://github.com/Coises/ColumnsPlusPlus/releases/tag/v1.1.5.1-Experimental
          It appears to be working reasonably well, but there hasn’t been a lot of testing yet. Feedback from anyone who cares to try it would be much appreciated.
            Hello, @coises and All,
            This morning, from your post above mine, I downloaded your experimental release of Columns++ ( ColumnsPlusPlus-1.1.5.1-Experimental-x64.zip ) and installed your plugin on my portable N++ v8.7.6. I even did not need your Quick Installer !
            So I decided to test this new version of our regex engine and to do some tests against my Total_Chars.txt file that you may download from my Drive Account :
            https://drive.google.com/file/d/1kYtbIGPRLdypY7hNMI-vAJXoE7ilRMOC/view?usp=sharing
            Here is an updated version of the contents of the Total_Chars.txt file, as I corrected two typo errors and I also split the range 0080 - 07FF in two ranges 0080 - 00FF and 0100 - 07FF in order to easily highlight the [[:unicode:]] range of chars
                |       Range        |    Description    |   Status   |      Number of Chars      | UTF-8 Encoding |  Number of Bytes  |
                |    0000  -   007F  |  PLANE 0 - BMP    |  Included  |             |        128  |    1 Byte      |              128  |
                |    0080  -   00FF  |  PLANE 0 - BMP    |  Included  |             |    +   128  |                |              256  |
                |                    |                   |            |             |             |    2 Bytes     |                   |-------
                |    0100  -   07FF  |  PLANE 0 - BMP    |  Included  |             |    + 1,792  |                |            3,584  |      \
                |    0800  -   D7FF  |  PLANE 0 - BMP    |  Included  |             |   + 53,248  |                |          159,744  |      |
                |    D800  -   DFFF  |  SURROGATES zone  |  EXCLUDED  |    - 2,048  |             |                |                   |      |
                |    E000  -   F8FF  |  PLANE 0 - PUA    |  Included  |             |    + 6,400  |                |           19,200  |      |
                |    F900  -   FDCF  |  PLANE 0 - BMP    |  Included  |             |    + 1,232  |    3 Bytes     |            3,696  |      |
                |    FDD0  -   FDEF  |  NON-characters   |  EXCLUDED  |       - 32  |             |                |                   |      |
                |    FDF0  -   FFFD  |  PLANE 0 - BMP    |  Included  |             |      + 526  |                |            1,578  |      |
                |                    |                   |            |             |             |                |                   |      |==>  [[:unicode:]]
                |    FFFE  -   FFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |      |
                |                       Plane 0 - BMP    | SUB-Totals |    - 2,082  |   + 63,454  |                |          188,186  |      |
                |   10000  -  1FFFD  |  PLANE 1 - SMP    |  Included  |             |   + 65,534  |                |          262,136  |      |
                |   1FFFE  -  1FFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |      |
                |   20000  -  2FFFD  |  PLANE 2 - SIP    |  Included  |             |   + 65,534  |                |          262,136  |      |
                |                    |                   |            |             |             |    4 Bytes     |                   |      |
                |   2FFFE  -  2FFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |      |
                |   30000  -  3FFFD  |  PLANE 3 - TIP    |  Included  |             |   + 65,534  |                |          262,136  |      |
                |   3FFFE  -  3FFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |      |
                |   40000  -  DFFFF  |  PLANES 4 to 13   |  NOT USED  |  - 655,360  |             |    4 Bytes     |                   |      |
                |   E0000  -  EFFFD  |  PLANE 14 - SPP   |  Included  |             |   + 65,534  |                |          262,136  |      /
                |   EFFFE  -  EFFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |
                |   FFFF0  -  FFFFD  |  PLANE 15 - SPUA  |  NOT USED  |   - 65,334  |             |                |                   |
                |   FFFFE  -  FFFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |
                •--------------------•-------------------•------------•-------------•-------------•    4 Bytes     •-------------------•
                |  100000  - 10FFFD  |  PLANE 16 - SPUA  |  NOT USED  |   - 65,334  |             |                |                   |
                |  10FFFE  - 10FFFF  |  NON-characters   |  EXCLUDED  |        - 2  |             |                |                   |
                |                                       GRAND Totals  |  - 788,522  |  + 325,590  |                |        1,236,730  |
                |                              Byte Order Mark - BOM  |             |             |                |                3  |
                |                                                     |  1,114,112 Unicode chars  |                |  Size  1,236,733  |
            And I’m pleased to tell you that, globally, this UTF-32 version works nicely ! Against my Total_Chars.txt, I got these results :
                 [\x{0000}-\x{007F}]   =>      128 chars ( OK )
                 [\x{0080}-\x{00FF}]   =>      128 chars ( OK )
                 [\x{0100}-\x{07FF}]   =>    1,792 chars ( OK )
                 [\x{0800}-\x{D7FF}]   =>   53,248 chars ( OK )
                 [\x{E000}-\x{F8FF}]   =>    6,400 chars ( OK )
                 [\x{F900}-\x{FDCF}]   =>    1,232 chars ( OK )
                 [\x{FDF0}-\x{FFFD}]   =>      526 chars ( OK )
                [\x{10000}-\x{1FFFD}]  =>   65,534 chars ( OK )
                [\x{20000}-\x{2FFFD}]  =>   65 534 chars ( OK )
                [\x{30000}-\x{3FFFD}]  =>   65 534 chars ( OK )
                [\x{E0000}-\x{EFFFD}]  =>   65 534 chars ( OK )
                 [\x{0000}-\x{007F}]   =>      128 chars ( OK ) coded with 1 byte
                 [\x{0080}-\x{07FF}]   =>    1,920 chars ( OK ) coded with 2 bytes
                 [\x{0800}-\x{FFFD}]   =>   61,406 chars ( OK ) coded with 3 bytes
                [\x{10000}-\x{EFFFD}]  =>  262,136 chars ( OK ) coded with 4 bytes
                 [\x{0000}-\x{EFFFD}]  =>  325,590 chars ( OK ) Total of characters
                [\x{0100}-\x{EFFFD}]   =>  325 334 chars ( OK ) Total chars OVER \x{00FF}
                [[:unicode:]]          =>  323 286 chars ( KO ) Should be 325,334 chars
            Regarding this error, note that 323,286 + 2,048 do give the right value 325,334 !
            The 2,048 value seems linked to the Surrogate pairs mechanism. However, my Total_Chars.txt file do NOT contain any Surrogate character at all So what !?
            Note also that the regex (?s). returns , as expected, 325,590 chars and that the simple . regex returns 325,572 chars. The difference concerns the 18 characters below, which are considered as line separator :
            LF 000A LINE FEED
            000C FORM FEED
            CR 000D CARRIAGE RETURN
            … 0085 NEXT LINE
 2028 LINE SEPARATOR
 2029 PARAGRAH SEPARATOR
            𐂅 10085 LINEAR B IDEOGRAM B105M STALLION
            𒀨 12028 CUNEIFORM SIGN AL TIMES USH
            𒀩 12029 CUNEIFORM SIGN ALAN
            𠂅 20085 [CJK Unified Ideographs Extension B]
            𢀨 22028 [CJK Unified Ideographs Extension B]
            𢀩 22029 [CJK Unified Ideographs Extension B]
            𰂅 30085 [CJK Unified Ideographs Extension G]
            𲀨 32028 [CJK Unified Ideographs Extension H]
            𲀩 32029 [CJK Unified Ideographs Extension H]
            󠂅 E0085 UNASSIGNED code-point
            󢀨 E2028 UNASSIGNED code-point
            󢀩 E2029 UNASSIGNED code-point
            Note, that, normally, the first six chars should ONLY be seen as a line separator. So, it"s quite funny that the same chars as \x{ 0085}, \x{2028} and \x{2029}, in the other planes, included in my file, are also considered as line separator !
            I also ran the test regarding the NUL character, described in this post :
            https://community.notepad-plus-plus.org/post/99736
            FIND ABC\x00XYZ
            REPLACE \x0--$0--\x{000}
            Which works and gives the correct result !
            I also tried some expressions with look-aheads and look-behinds, containing overlapping zones !
            For instance, against this text aaaabaaababbbaabbabb, pasted in a new tab, with a final line-break, all the regexes, below, give the correct number of matches :
            ba*(?=a)   =>  4 matches
            ba*(?!a)   =>  9 matches
            ba*(?=b)   =>  8 matches
            ba*(?!b)   =>  5 matches
            (?<=a)ba*  =>  5 matches
            (?<!b)ba*  =>  5 matches
            (?<=b)ba*  =>  4 matches
            (?<!a)ba*  =>  4 matches
            However, I could not test this irritating problem :
            Backward regex searches, for NON ANSI files, stops as soon as it matches a character with code-point over \x{007F}
            Just because you do not allow backward searches when choosing the Regular expression search mode ! May be you could add it among all the Columns++ options ?
            In the end, I can say that this experimental release is a valuable improvement and should be adopted in your Columns++ plugin, as well as in the N++ Boost regex engine ;-))
            @coises, Many thanks for your efforts, so far !
            P.S. :
            Just a small drawback :
            • For the four regexes [\x{10000}-\x{EFFFD}], [\x{0000}-\x{EFFFD}], [\x{0100}-\x{EFFFD}] and [[:unicode:]] which match more than 200,000 occurences, the Select All option of the Count button leads to the message the program des not respond :-((
            CoisesC Alan KilbornA 4 Replies Last reply Reply Quote 2
              Coises @guy038
              @guy038 said in Search for character classes but not replace them:
              Thank you!
              The tests you’ve run and the file will be very helpful in finding and fixing errors. I really appreciate your help.
                Coises @guy038
                Note also that the regex (?s). returns , as expected, 325,590 chars and that the simple . regex returns 325572 chars. The difference concerns the 18 characters below, which are considered as line separator :
                LF 000A LINE FEED
                000C FORM FEED
                … 0085 NEXT LINE
 2028 LINE SEPARATOR
                I found the cause of this (a default template in boost::regex that required specialization for 32-bit characters) and “fixed” it in my local copy… but that leads me to a question.
                The boost::regex documentation says the point (without (?s)) matches anything but new line.
                The Notepad++ documentation says it matches anything but \r or \n.
                The code (allowing for it being for 16-byte characters) says the first six you listed (line feed, form feed, carriage return, next line, line separator, paragraph separator).
                The web site Regular-Expressions.info notes that there is great variety in how this is handled, observing that Boost is unusual in including the Form Feed. Examining your Total_Chars.txt file, I notice that . matches the vertical tab but skips the form feed, though both are displayed by Notepad++ as control characters and do not create a line break. Apparently Scintilla can, under some conditions, recognize “Unicode line endings,” but this is dependent on the active lexer; the documentation does not say what “Unicode line endings” are and in any case, Notepad++ never enables them.
                So, since I have to override the Boost default anyway… what should be excluded by . without (?s)?
                My thought is that it should be the same things Scintilla recognizes as line breaks and the Notepad++ documentation states: just \n and \r. The character classes \s and \v and their complements are independent of this and match as expected (with \v matching the first six you listed plus the vertical tab).
                  Coises @guy038
                  It turned out to be linked in that I made a typo in the code that was supposed to recognize the surrogate range, which caused it to treat U+D000 - U+D7FF as invalid Unicode characters (which they are not). Thank you for catching that! It will be fixed in the next experimental version.
                  As described in more detail in my previous post, this turned out to be easy to fix, but I’m now wondering what is the best way to fix it. Your thoughts on that would be very welcome.
                  I’m unlikely to do that. The search in Notepad++ is “managed” by Scintilla — Scintilla is built to allow integration with a search engine like Boost, while Scintilla still controls the process. The search in Columns++ doesn’t work that way: I use the Boost engine directly (mainly because I needed access to some information Scintilla doesn’t expose to implement my numeric calculation extensions). There’s nothing I see in boost::regex that supports backward searching; I’d have to implement that from the ground up. I’m not even sure what it’s supposed to mean: if you have a variable-length search, how much do you “back up” after a match? Just one character? Do you refuse to match until the new match doesn’t overlap the old one? What if there’s a match that doesn’t overlap, but it isn’t the first/best match? (You can’t just change the end of the searchable region because the expression might have look-aheads which should be able to overlap.)
                  • For the four regexes [\x{10000}-\x{EFFFD}], [\x{0000}-\x{EFFFD}], [\x{0100}-\x{EFFFD}] and [[:unicode:]] which match more than 200,000 occurences, the Select All option of the Count button leads to the message the program does not respond :-((
                  I have to think about how to do this, but indeed there should be a way to interrupt that process. (It does complete eventually.) The reason it takes so long is that Select All makes a multiple selection with one selection for each match: so you are asking Scintilla to make a multiple selection with over 200,000 component selections. Either I need a sanity check on the number of matches or a progress dialog with a Cancel button that gets raised after more than a couple of seconds have passed.
                    Alan Kilborn @guy038
                    Here is an updated version of the contents of the Total_Chars.txt file, as I corrected…
                    When one downloads from that link, there is nothing updated, as the latest file in the archive is from 2023.
                      Hi, @alan-kilborn and All,
                      Alan, may be my message was a bit ambiguous !
                      The total message said explicitly :
                      Thus, the contents of the Total_chars.txt has NOT changed since the date I published it on my Drive Account
                      But, it’s the description of the zones of this file which has been updated !!
                      The part :
                          |    0080  -   0FFF  |  PLANE 0 - BMP    |  Included  |             |    + 1,920  |    2 Bytes     |            3,840  |
                      Has been changed into :
                          |                    |                   |            |             |             |    2 Bytes     |                   |
                      And this line :
                          |    F900  -   FDFC  |  PLANE 0 - BMP    |  Included  |             |    + 1,232  |    3 Bytes     |            3,696  |
                      So, you can notice the two typo errors :
                      • The end of range 0FFF which should be 07FF
                      • The end of range FDFC which should be FDCF
                      I saw these errors when I calculated the number of chars of these zones, in @coises’s post !
                        @guy038 said :
                        the contents of the Total_chars.txt has NOT changed since the date I published it on my Drive Account…it’s the description of the zones of this file which has been updated !!
                        So… what you’re saying is that if one wants to use the file (and appreciate it fully) they really have to piece together all of its documentation, e.g. the “description of the zones”, from comments you’ve made about it in this and other Community postings that refer to the file?
                        OK…but it’s rather traditional when you publish something, to have everything all in one place.
                        Full admission: I haven’t really dug into the file yet, but I plan to…
                        EDIT: OK, I’ve looked a little bit now, and the fact that Total_chars.txt only contains 3 lines, one of which is quite long, had me wishing for more of a “separated” approach, like the author of these data files provided: https://github.com/bits/UTF-8-Unicode-Test-Documents
                        Hopefully this discussion is still considered on-topic for N++; it really needs to be an editor that can handle Unicode well.
                          Hi, @coises and All,
                          You said,
                          I think that this reasoning is the right one ! More over, note that we use the same reasoning when we want to find all chars but a specific one, in each single line : we use the regex [^c\r\n], where c is the character we do not want to !
                          Thus, against my Total_Chars.txt file, the regex (?s). should return 325,590 occurrences and the regex (?-s). should return 325,588 occurrences
                          Now, regarding my question :
                          I do understand all the reasons why you are not inclined to do so ! However, note that, as regularly using the regexBackward4PowerUser="yes" option, in the FindHistory node of the config.xml file, I can assure you that a lot, but not all, of regexes can be processed in backward direction ! Unfortunately, with our present Boost regex engine, you can verify my assertion :
                          I also tested the search of invalid UTF-8 bytes. To do so :
                          • Open a new N++ tab. ( I assume that its current encoding is UTF-8 ! )
                          • Run the Encoding > Convert to ANSI menu option
                          • Paste the text below, in this new ANSI tab
                          ABC ퟿ XYZ   \x{D7FF}  ED 9F BF  LAST  valid char BEFORE Surrogates range
                          ABC í € XYZ   \x{D800}  ED A0 80  FIRST SURROGATE char
                          ABC í¿¿ XYZ   \x{DFFF}  ED BF BF  LAST  SURROGATE char
                          ABC  XYZ   \x{E000}  EE 80 80  First valid char AFTER  Surrogates range
                          ABC € XYZ
                          ABC  XYZ
                          ABC ‚ XYZ
                          ABC ƒ XYZ
                          ABC „ XYZ
                          ABC … XYZ
                          ABC † XYZ
                          ABC ‡ XYZ
                          ABC ˆ XYZ
                          ABC ‰ XYZ
                          ABC Š XYZ
                          ABC ‹ XYZ
                          ABC Œ XYZ
                          ABC  XYZ
                          ABC Ž XYZ
                          ABC  XYZ
                          ABC  XYZ
                          ABC ‘ XYZ
                          ABC ’ XYZ
                          ABC “ XYZ
                          ABC ” XYZ
                          ABC • XYZ
                          ABC – XYZ
                          ABC — XYZ
                          ABC ˜ XYZ
                          ABC ™ XYZ
                          ABC š XYZ
                          ABC › XYZ
                          ABC œ XYZ
                          ABC  XYZ
                          ABC ž XYZ
                          ABC Ÿ XYZ
                          ABC   XYZ
                          ABC ¡ XYZ
                          ABC ¢ XYZ
                          ABC £ XYZ
                          ABC ¤ XYZ
                          ABC ¥ XYZ
                          ABC ¦ XYZ
                          ABC § XYZ
                          ABC ¨ XYZ
                          ABC © XYZ
                          ABC ª XYZ
                          ABC « XYZ
                          ABC ¬ XYZ
                          ABC ­ XYZ
                          ABC ® XYZ
                          ABC ¯ XYZ
                          ABC ° XYZ
                          ABC ± XYZ
                          ABC ² XYZ
                          ABC ³ XYZ
                          ABC ´ XYZ
                          ABC µ XYZ
                          ABC ¶ XYZ
                          ABC · XYZ
                          ABC ¸ XYZ
                          ABC ¹ XYZ
                          ABC º XYZ
                          ABC » XYZ
                          ABC ¼ XYZ
                          ABC ½ XYZ
                          ABC ¾ XYZ
                          ABC ¿ XYZ
                          ABC À XYZ
                          ABC Á XYZ
                          ABC Â XYZ
                          ABC Ã XYZ
                          ABC Ä XYZ
                          ABC Å XYZ
                          ABC Æ XYZ
                          ABC Ç XYZ
                          ABC È XYZ
                          ABC É XYZ
                          ABC Ê XYZ
                          ABC Ë XYZ
                          ABC Ì XYZ
                          ABC Í XYZ
                          ABC Î XYZ
                          ABC Ï XYZ
                          ABC Ð XYZ
                          ABC Ñ XYZ
                          ABC Ò XYZ
                          ABC Ó XYZ
                          ABC Ô XYZ
                          ABC Õ XYZ
                          ABC Ö XYZ
                          ABC × XYZ
                          ABC Ø XYZ
                          ABC Ù XYZ
                          ABC Ú XYZ
                          ABC Û XYZ
                          ABC Ü XYZ
                          ABC Ý XYZ
                          ABC Þ XYZ
                          ABC ß XYZ
                          ABC à XYZ
                          ABC á XYZ
                          ABC â XYZ
                          ABC ã XYZ
                          ABC ä XYZ
                          ABC å XYZ
                          ABC æ XYZ
                          ABC ç XYZ
                          ABC è XYZ
                          ABC é XYZ
                          ABC ê XYZ
                          ABC ë XYZ
                          ABC ì XYZ
                          ABC í XYZ
                          ABC î XYZ
                          ABC ï XYZ
                          ABC ð XYZ
                          ABC ñ XYZ
                          ABC ò XYZ
                          ABC ó XYZ
                          ABC ô XYZ
                          ABC õ XYZ
                          ABC ö XYZ
                          ABC ÷ XYZ
                          ABC ø XYZ
                          ABC ù XYZ
                          ABC ú XYZ
                          ABC û XYZ
                          ABC ü XYZ
                          ABC ý XYZ
                          ABC þ XYZ
                          ABC ÿ XYZ
                          • Now, choose the Encoding > UTF-8 encoding. So all characters of this ANSI file are re-interpreted as they were UTf_8 chars
                          => You should see, between the strings ABC and XYZ :
                          -The last VALID UTF-8 char ( ED 9F BF ) before the SURROGATE range
                          • The 3-bytes sequence of the first SURROGATE char, which is an INVALID sequence
                          • The 3-bytes sequence of the last SURROGATE char, which is an INVALID sequence
                          • The first VALID UTF-8 char ( EE 80 80 ) after the SURROGATE range
                          Then, a list of the 128 IVALID UTF-8 characters as the UTF-8 encoding does NOT allow any 1-byte character OVER \x{007F} !
                          Now :
                          • Move the caret to the first empty line
                          • Run the option Plugins > Columns++ > Search...
                          • Enter the range [\x{DC80}-\x{DCFF}] in the Find what : zone
                          • Click on the Find First button
                          • The Search region is set to the entire document
                          • The first INVALID byte \xED is selected
                          • Click on the Find Next button => It will select, one after another, all the other IVALID UTF-8 characters of this new tab !
                          So, @coises, your new implementation works correctly, regarding the INVALID UTF-8 chars and I’m longing for your second experimental version ;-))
