    Using Mark (Markers) and Styles
    34 Posts 6 Posters 32.8k Views 3 Watching
    • Alan KilbornA Online
      Alan Kilborn @Sridhar Raghavan
      @Sridhar-Raghavan said in Using Mark (Markers) and Styles:
      Is there a function to hide bookmarked lines? (and of course unhide if it can be defined)
      Show Only Marked Areas. (and hide all Un-Marked Areas). Specific to a color.
      And the counterpart Unhide Marked Areas of Specific Color.
      Notepad++ has a “hide / unhide lines” feature, see View menu > Hide Lines, or maybe more handy, on the right-click context menu (bottom entry called Hide Lines).
      But it is purely a user selection thing – there is no way within Notepad++ to hide lines based upon a result of a search/mark operation.
      Scripting can do it, but there’s a limitation: It would get out of sync with user interface control of hidden lines.
      If that’s not a big deal to you (you would only hide/unhide lines via scripted commands), then that’s doable.
      • Sridhar RaghavanS Offline
        Sridhar Raghavan
        Alan
        I agree it is better to use Scripting to weave together simple building block functions into more powerful personalized ones. But, as you pointed out, unless Scripting is done carefully, one may easily break the consistencies ensured rigorously in the core code.
        Just a quick/simple question.
        I installed your code and it functions fine as intended.
        How do I Edit that Script code? Do not see any obvious menus for it.
        More generally, what is the basic edit/test iterate cycle?
        So I can experiment with your code.
        br Sri.
        P.S. I am holding off on systematic reading the full Scripting Tutorial as yet.
        Alan KilbornA 2 Replies Last reply Reply Quote 1
          Ah, yes, that’s a bit of a “trick” for the first-timers.
          To run the script you select it via the menus (as I’m sure you’ve found).
          To edit it (after the first time you’ve closed it, of course, otherwise you don’t have to find/open it to edit it, it’s just there), you hold down Ctrl while you pick its name from the menus. This opens the file for editing rather than running the script.
            I thought of another bit of a downside to hiding lines:
            If you switch away from the tab in which you’ve hidden lines (via script), when you return to that tab, all the lines become visible again.
            That makes for an easy way to make lines visible again in a simple demo, but in a real application the code would have to handle that situation reasonably, which makes the code much more complicated.
            Here’s a simple demo for only showing lines with hits and two lines before and three lines after:
            # -*- coding: utf-8 -*-
            from Npp import editor, notepad
            # Notepad++'s style numbers:
            #  25 = Style #1
            #  24 = Style #2
            #  23 = Style #3
            #  22 = Style #4
            #  21 = Style #5
            class T_21275a(object):
                def __init__(self):
                    lines_above = 2
                    lines_below = 3
                    search_input = notepad.prompt('Enter search string:', '', '')
                    if search_input == None or len(search_input) == 0: return
                    matches = []
                    editor.search(search_input, lambda m: matches.append(m.span(0)))
                    if len(matches) > 0:
                        color_input = notepad.prompt('Enter style color number (1-5):', '', '')
                        try:
                            color_input = int(color_input)
                        except ValueError:
                            return
                        if 1 <= color_input <= 5:
                            color_input -= 1
                            editor.hideLines(1, editor.getLineCount() - 1)
                            for (match_start_pos, match_end_pos) in matches:
                                editor.setIndicatorCurrent(25 - color_input)
                                editor.indicatorFillRange(match_start_pos, match_end_pos - match_start_pos)
                                match_start_line = editor.lineFromPosition(match_start_pos)
                                match_end_line = editor.lineFromPosition(match_end_pos)
                                show_start_line = match_start_line - lines_above
                                if show_start_line < 1: show_start_line = 1
                                show_end_line = match_end_line + lines_below
                                if show_end_line > editor.getLineCount() - 1: show_end_line = editor.getLineCount() - 1
                                editor.showLines(show_start_line, show_end_line)
            if __name__ == '__main__': T_21275a()
              Well, to be honest, I think in the core code the hidden line feature is just not that good. So much for the need for “consistencies ensured rigorously”. :-)
              And, strangely, in all of the forum postings here, hiding and showing lines again is very rarely discussed. Probably, because in Notepad++ the feature is very basic as I described earlier.
                Alan Kilborn @Alan Kilborn
                @Alan-Kilborn said in Using Mark (Markers) and Styles:
                As an example, it is easy to get the UI out of sync just using the built-in features (no scripting).
                Example:
                Start with text:
                one
                two
                three
                four
                five
                six
                seven
                eight
                nine
                ten
                Make a selection of some lines:
                Right-click that selection and pick Hide Lines to obtain:
                Make another selection, like so:
                Left-click the green arrow in the margin on line 2.
                This seems like it should expand the text back to a no-lines-hidden state, or perhaps the previous state where lines 5, 6 and 7 were the only hidden ones.
                But what we get is:
                So we do get the state where lines 5, 6 and 7 are the hidden ones.
                But…there’s no way to ever unhide them (well, switching tabs and back does it!)
                There’s no right-pointing green arrow, and clicking on the left-pointing arrow does nothing.
                So the conclusion is that this feature is broken (if I can break it so easily).
                ? 3 Replies Last reply Reply Quote 1
                  Sridhar Raghavan
                  Thanks Alan for that tip. I would have never found it by trying things (hoping for the hidden commands!). That gets me going now.
                  Thanks for the quick work on the code for the “windowed” display. Great.
                  I think your code with additional check boxes and drop downs is rapidly getting to becoming a good plugin!!
                  It was a general experiential statement on my part that APIs and Scripting languages are after-thought add-ons, done with less rigor. But not always the case, including the example you cite.
                  br Sri.
                    Hi, @sridhar-raghavan, @alan-kilborn and All,
                    Just tried your second version, using 1 line before hit and 1 line after it. Interesting, indeed, with the “Hide Lines” mechanism. Just enable the line number margin !
                    Of course, as soon as you switch to another tab and switch back to your file, all the hidden lines appear again !
                    Now, I thought about two improvements. But, Alan, they are just suggestions and ONLY IF @sridhar-raghavan would need it, too !
                    • By default, the Python search is sensible to case et does not care about the whole word notion. So, could it possible to search for any case and to search for whole words only ?
                    • I thought that you could also enter all the parameters in an unique prompt window !
                    • With double quotes to surround expressions containing space characters
                    • With inside a couple of parentheses :
                      • w would mean Word only
                      • i would mean Ignore case
                      • r would mean Remove all styles
                      • # would mean Style #
                    When absent, each parameter would be supposed to be the default present Python script behavior !
                    So, for instance, the text License (rw5) software (i3) "GNU GENERAL PUBLIC LICENSE" (iw43) would mean :
                    • Remove all styles first
                    • Highlight any word License, with this exact case, in style 5
                    • Highlight any string software, whatever its case, in style 3
                    • Highlight any exact expression GNU GENERAL PUBLIC LICENSE, whatever its case, in style 4 AND in style 3, too
                      Alan Kilborn @guy038
                      @guy038 said in Using Mark (Markers) and Styles:
                      Yes, this limitation was mentioned earlier.
                      It can be avoided with more code, but as this was just intended to be a demo to show @Sridhar-Raghavan the possibilities of scripting, I didn’t do it.
                      Regarding other changes: Yes, with scripting the possibilities are limitless! :-)
                      • ? Offline
                        A Former User @Alan Kilborn
                        Maybe you already know, as > 2 years passed, but if not: I could not reproduce that bug, so I guess it’s been fixed.
                          Alan Kilborn @Guest
                          @Victorel-Petrovich said in Using Mark (Markers) and Styles:
                          Not sure what you mean has been fixed…
                          • ? Offline
                            • ? Offline
                              @Alan-Kilborn , the bug in your message above:
                              Example:
                              Start with text:
                              one
                              two
                              three
                              four
                              five
                              six
                              seven
                              eight
                              nine
                              ten
                              But what we get is:
                                Alan Kilborn @Guest
                                Ah, OK – I thought you meant something with the script.
                                Yes, the feature is very broken, for many reasons.
                                This has long been known.
