    Python gotoLine() Not going to line after Open()
    9 Posts 4 Posters 1.2k Views 2 Watching
    • Anthony BlincoA Offline
      Anthony Blinco
      I have a file that has a list of files and linenumbers. I want to click on a line and hit an Fkey which will load the file and goto the line.
      My code looks like this;
      print("Opening "+os.path.normpath(c)+"...")
      notepad.open(c)
      print("Going to line "+parms[2]+"...")
      editor.gotoLine(int(parms[2]))
      My Console output looks like this;
      Opening excpmon.cbp...
      Going to line 136...
      It loads the file fine but it doesn’t goto the line. What have i done wrong?
      Thanks in advance for any help
      EkopalypseE Alan KilbornA 2 Replies Last reply Reply Quote 0
        Ekopalypse @Anthony Blinco
        @Anthony-Blinco
        Could it be that there are notifications or threads involved
        which result in executing gotoLine before the document has been loaded?
        • Alan KilbornA Online
          Alan Kilborn @Anthony Blinco
          @Anthony-Blinco said in Python gotoLine() Not going to line after Open():
          I changed your code a bit, to:
          p = r'd:\blah.txt'
          print("Opening "+ p + "...")
          notepad.open(p)
          line = 12
          print("Going to line " + str(line) + "...")
          editor.gotoLine(line)
          and, running it, it didn’t have a problem opening the file and moving to the correct line.
            Anthony Blinco
            @Alan-Kilborn I’m not sure what the difference (between my code and yours) is there
            It is very weird. If I turn word wrap off it works, if word wrap is on it doesn’t work (For my primary file, not the loaded file).
            I do have pre-processor python code that runs when a file is loaded.
            Is there anyway to wait until there is no other processing and then goto the line?
            Alan KilbornA dailD 3 Replies Last reply Reply Quote 0
              I’m not sure what to think about that…
              I’m not sure what “pre-processor python code” exactly means…
              You could certainly do some kind of “sleep”.
              You might start with time.sleep() for experimentation purposes.
              A threading timer is a bit more elegant if the basic sleep works.
              I’m not convinced you should need it, but only you have your exact situation.
              • dailD Offline
                dail @Anthony Blinco
                A quote from the Scintilla documentation
                Wrapping is not performed immediately there is a change but is delayed until the display is redrawn. This delay improves performance by allowing a set of changes to be performed and then wrapped and displayed once. Because of this, some operations may not occur as expected. If a file is read and the scroll position moved to a particular line in the text, such as occurs when a container tries to restore a previous editing session, then the scroll position will have been determined before wrapping so an unexpected range of text will be displayed. To scroll to the position correctly, delay the scroll until the wrapping has been performed by waiting for an initial SCN_PAINTED notification.
                  So what didn’t register with me is that “word wrap” is a global setting, it affects all files. So if you have one “wrapped” you have them all “wrapped”. So saying something like “word wrap is on…for my primary file not the loaded file” isn’t really a valid statement.
                  So yes, I think in light of that plus @dail 's input, a lot more is starting to make sense now as to what is happening for you. :-)
                    Ekopalypse
                    Hm, wrapping has an impact on scripts, learned something new today.
                      Anthony Blinco
                      Awesome advice as usual. A 10ms delay did it.
                      I will investigate the SCN_PAINTED notification to implement it properly
                      Thanks and very much appreciated
