    With Dark Mode Enabled, printed text is too faint to read on printer
    3 Posts 2 Posters 3.0k Views 2 Watching
    • Robert OsorioR Offline
      Robert Osorio
      I love dark mode, but I can’t print in dark mode. It’s not just one printer. I Same result on an HP Laser, Epson ink jet, or Primo PDF. Also happens on two different PCs.
      Tried deleting all the .xml files in \AppData\Roaming\Notepad++ to reset NotePad++ back to factory defaults, and then just enabled Dark Mode, and same issue. Dark mode off = legible print (not dark black, more like 50% dark text, but quite readable). Dark mode on = extremely light illegible text on laser. Nothing at all on Primo PDF or ink jet.
      NOTE: I line numbers ARE dark and legible, it’s just the text that’s very light or invisible.
      Any help appreciated.
      Thx
      Bob
        PeterJones @Robert Osorio
        @Robert-Osorio ,
        This sounds similar to this note re: printing and v8.1.1 dark mode; maybe my reply there will be of help for you, as well.
          Robert Osorio
          Peter,
          THANK YOU!
