    Docked panels do not restore when multi instances is used
    3 Posts 2 Posters 732 Views 2 Watching
    • Mikael WillbergM Offline
      Mikael Willberg
      I think there is a bug where Docked panels do not restore when multi instances is used. All versions mentioned here are portable ones and saving settings works ok.
      • Clean installation and settings
      • Set preferences / Multi Instance = Always in multi-instance mode
      • View / Function List = Enable
      Launch 8.1.9 exe
      • Application windows opens and function list is visible
      • Keep application open
      Launch 8.1.9 exe again
      • Application window opens and fuction list is not visible
      The last version in which this works ok is 7.9.1 so I suspect that the fix 8005 for 7.9.2 has broken this functionality:
      Folder as Workspace panel opened even with “-nosession” #8005
      I want to have the “document list” visible, but “function list” is used in this example as the settings is in the same place across versions.
        PeterJones @Mikael Willberg
        @mikael-willberg ,
        There is still an open issue about that: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/9710
        You might want to add your information to that as well.
        Mikael WillbergM 1 Reply Last reply Reply Quote 1
          Mikael Willberg @PeterJones
          @peterjones Done, added this same info to issue 9710.
