    Default for C++ language
    6 Posts 3 Posters 2.1k Views 2 Watching
    • queenidog1Q Offline
      queenidog1
      I only use NPP for editing (printing) C++ programs but I have to choose that language everytime I paste a C++ program into NPP.
      Is there a way to KEEP it as the DEFAULT? i’m sure it worked that way before (before computer crashes, upgrades to win11, new NPP version, etc).
      I would have thought it would be in Preferences
        PeterJones @queenidog1
        @queenidog1 ,
        Settings > Preferences > New Document > Default Language = C++
        Reference
        • https://npp-user-manual.org/docs/preferences/#new-document
        • Trevor WT Offline
          Trevor W
          I would like the same.
          The following link may solve your problem @queenigog1, but not mine.
          https://community.notepad-plus-plus.org/topic/11687/change-default-language
          Using this method, the filename extension has to match the language to stay that language each time the files are opened.
          However, my CAD software expects a different file extension (.px) to the language used (.pas)
          I would like to suggest making the default language the last language used.
          Therefore, since most people switch languages infrequently, this should suit all.
          Maybe with a switch in setting if people do or don’t want the option.
          I’m not a coder in C++ so I can’t do this myself.
            PeterJones @Trevor W
            @trevor-w ,
            Then use the Style Configurator to set px as an extra extension for Pascal.
            … because the Default Language only applies to new files, not to opening existing files. If you want a given non-standard extension to always be interpreted as a particular language, you have to tell Notepad++ that.
            • Trevor WT Offline
              Trevor W
              Thanks Peter, that worked.
              & this should be the solution to @queenidog1 problem too.
              Ta
                @trevor-w said in Default for C++ language:
                that worked.
                Glad it worked for you.
                Doubtful. As explicitly stated, the original post was about pasting text into a new document (that is, what you get when you open Notepad++ with no previous session open, or what you get from a File>New), whereas your question was how to treat an already-existing file that you open with File>Open or equivalent. Those are two separate things, and the answer I gave to each is the right way of handling those two separate situations.
