    Right-Mouse Click to Line/Sort
    3 Posts 2 Posters 846 Views 1 Watching
    • jose isaias cabreraJ Offline
      jose isaias cabrera
      Greetings!
      Is there a way to add an option to the right-mouse-click on a Window and be able to choose Edit/Line Operations/Sort Lines… ? Any way to make this easier than having to click/click/click? Thanks.
      josé
        Alan Kilborn @jose isaias cabrera
        @jose-isaias-cabrera
        Yep, start here in the user manual and see if you can figure it out.
        https://npp-user-manual.org/docs/config-files/#:~:text=files as well.)-,The%20context%20menu%3A%20contextMenu.xml,-The%20context%20menu
        jose isaias cabreraJ 1 Reply Last reply Reply Quote 3
          jose isaias cabrera @Alan Kilborn
          @alan-kilborn Thank you, sire. This is what I was looking for. I appreciate your effort.
          josé
