    newbee, macros and basic algorithm with Python Script
    34 Posts 5 Posters 11.2k Views 2 Watching
      Alan Kilborn @mpheath
      @mpheath said in newbee, macros and basic algorithm with Python Script:
      The replaced text may have \n EOLs. If \r\n is wanted, then change this section
      A smooth way to handle this would be, using your line of code as a basis:
      text += line[1] + ['\r\n', '\r', '\n'][editor.getEOLMode()]
      This will put the correct line-ending on according to the current tab’s setup.
        Alan Kilborn @Alan Kilborn
        I don’t know that this is an appropriate forum for teaching someone the ins and outs of programming Python for solving a very specific problem.
        While I appreciate that there are some tie-ins to editor objects to get and set the active tab’s text, really this is just a straight Python programming problem.
        As such, since @mpheath seems interest in helping @Mathias-Lujan with this, can I suggest they get together using the forum’s direct chat feature and expand/explain the effort in that way?
        Use this button to do so:
        Mathias LujanM 1 Reply Last reply Reply Quote 0
        • Mathias LujanM Offline
          Mathias Lujan @Alan Kilborn
          @alan-kilborn I think we are near to the solution. Let me just understand and implement it. I don’t want to learn Python programming, I just want solve my problem.
          As I said :
          " I would love to find a solution with a basic macro which I can set up myself with your help. It would be easier for everybody.
          I think my problem can’t be solve with REPLACE.
          I just have to :
          IF (find() == true)
          then MOVE a line;
          ELSE
          then CREATE a line;
          So, macro N++ or Python Script to solve my problem ?
            Alan Kilborn @Mathias Lujan
            @mathias-lujan said in newbee, macros and basic algorithm with Python Script:
            That’s fine, for you. But this forum doesn’t take kindly to those that don’t want to learn. It means someone else has to (choose to) do your work for you. It also probably means that when you need changes, however small, you’ll come here, expecting more free work done on your behalf.
              Mathias Lujan @Mathias Lujan
              I never used Python and it would take me a lot of time to code my basic algorithm. For a regular, this will probably only take an hour or less.
              I wrote my basic algorithm (Algorithme rename.txt) and I hope somebody could code it entirely or help me for the Python part.
              I would say : I just want to solve my problem with basic Python programming, not to code in general.
              Anyway, I feel that most of the work is already done by @mpheath and I just have to implement and test his code. I will try to do that this week.
              Thanks again for all.
              Paul WormerP 2 Replies Last reply Reply Quote 0
              • Paul WormerP Offline
                Paul Wormer @Mathias Lujan
                @mathias-lujan
                Maybe this is mustard after the meal as we say in Dutch, but here is another solution to your problem:
                # -*- coding: utf-8 -*-
                from __future__ import print_function # Python 2.7
                from Npp import *
                def moveLine(stringToBeMoved, targetString):
                    try:
                        startW, endW  = editor.findText(FINDOPTION.WHOLEWORD, 0, lenFile, stringToBeMoved)
                    except:
                        line = stringToBeMoved
                        #notepad.messageBox(stringToBeMoved + ' not found')
                    else:
                        lineNmbr = editor.lineFromPosition(startW)
                        line = editor.getLine(lineNmbr).replace('\r\n', '')
                        editor.deleteLine(lineNmbr)
                    try:
                        startW, endW  = editor.findText(FINDOPTION.WHOLEWORD, 0, lenFile,  targetString )
                    except:
                        notepad.messageBox(targetString + ' not found')
                        return
                    else:
                        endLine = editor.getLineEndPosition(editor.lineFromPosition(endW))
                        editor.gotoPos(endLine)
                        editor.addText('\r\n'+line)
                items = [
                    '[song]',
                    'name =',
                    'artist =',
                    'album =',
                    'genre =',
                    'year =',
                    'track =',
                    'loading_phrase =',
                    'charter =',
                    'frets =',
                    'song_length =',
                    'delay =',
                    'diff_guitar =',
                    'diff_bass =',
                    'diff_guitar_coop =',
                    'diff_rhythm =',
                    'diff_vocals =',
                    'diff_keys =',
                    'diff_bass_real =',
                    'diff_guitar_real =',
                    'diff_dance =',
                    'diff_bass_real_22 =',
                    'diff_guitar_real_22 =',
                    'diff_vocals_harm =',
                    'sysex_high_hat_ctrl =',
                    'multiplier_note =',
                    'pro_drums =',
                    'background =',
                    'last_play ='
                for i in range(0, len(items)-1):
                    stringToBeMoved = items[i+1]
                    targetString = items[i]
                Paul WormerP 1 Reply Last reply Reply Quote 1
                  Paul Wormer @Paul Wormer
                  @paul-wormer
                  Bug: add the line
                  lenFile  = editor.getLength()
                  as first line to the function moveLine (it is the default of findText, which is why I did not see it)
                    @mathias-lujan
                    I tested my little script on your first example and it worked exactly the way you wanted. Today I tested the script on your second example and it works fine again, except that it fails on many undefined items (keywords).
                    If you want any script to work you have to define a fixed set of keywords that appear in each and every one of your files. The fact that the sets of keywords change between your files makes me wonder how much coding experience you have. Any programmer understands that automatizing your editing is impossible when the keywords vary between files. When you have to introduce a separate set of keywords for every file, you may as well do the editing by hand.
                      Alan Kilborn @Paul Wormer
                      @paul-wormer said in newbee, macros and basic algorithm with Python Script:
                      I don’t know that this is true. A keyword could belong to the set of undefined keywords, it just couldn’t be specially manipulated (reordered into the top grouping the OP seems to want for some keywords). It could certainly “tag along” in the reformatting effort (although apparently not in the script you wrote).
                      Paul WormerP 1 Reply Last reply Reply Quote 0
                        Paul Wormer @Alan Kilborn
                        @alan-kilborn
                        The OP wasn’t very clear about what he wanted exactly, but I assumed that he wanted a definite order for all keywords appearing in a certain file. If he wanted to distinguish two kinds of keywords - those with a well-defined order and a those with no order (except perhaps that they come after the ordered ones) - he should have stated this explicitly.
                        Mathias LujanM 1 Reply Last reply Reply Quote 1
                          Mathias Lujan @Paul Wormer
                          @paul-wormer It’s true, I have not been very clear.
                          I had just proposed two very different examples. I were thinking that was enough to illustrate it.
                          In my 5000 ‘song.ini’, there is all the configurations. That’s why I want to organize that.
                          I’m sorry for this imprecision which makes you contribute out of the subject.
                            Mathias Lujan
                            Otherwise, I’m extremely grateful to @mpheath who gave me the solution “clé en main” (ready to use). I have understood it thanks to his explanations. I have implemented both Notepad++ Python Script and Standalone recursive Python Script : both work perfectly.
                            I might even consider changing more elements very easily (thanks to list ‘presets’), and, amazing, modify the 5000 files without open them in Notepad++ (a lot of time saving). That’s a lot more than I expected.
                            BIG THANKS to @mpheath and other for contributions.
                            I share with you the two scripts in final version.
                            The Notepad++ Python Script :
                            # coding: utf8
                            # Here is PythonScript to replace the text in the current editor pane.
                            def ini_reindex():
                                # Get text from the editor pane.
                                text = editor.getText()
                                if text == '':
                                    return ''
                                # Presets ordered as the top-most keys.
                                presets = ['name', 'artist', 'album', 'genre', 'year', 'track',
                                           'loading_phrase', 'charter', 'frets', 'song_length']
                                # Create a list of indexed lines.
                                lines = [[-1, line.replace('\n', '')] for line in text.splitlines()]
                            	# Creates a list of lists like [[-1, 'Line 1'], [-1, 'Line 2'], [-1, 'Line 3'], ...]
                            	# The -1 will be replaced with numbers to order the lines later for sorting.
                                # Add preset keys if not found.
                                for item in presets:
                                    for line in lines:
                                        if line[1].startswith(item + ' = '):
                            			# item is each of presets list of ['name', 'artist', 'album', 'genre', 'year', 'track', 'loading_phrase', 'charter', 'frets', 'song_length']
                            			# So 1st one it trys to match is start with name = . Then tries artist = … until all items are tried. If break does not occur, then the else happens and the item key is added to the list.
                                            break
                                    else:
                                        lines.append([-1, item + ' = '])
                            			# lines is a list and .append is a method to add to the list.
                            			# If the else ocurrs for not finding example 'name = ', then [-1, 'name = '] is added to the list.
                                # Index the preset keys.
                                index = 0
                                    for line in lines:
                                        if line[0] == -1:
                            			# This is lines with a -1 index, not given a line number yet. If starts with [ (section header) or item + ' = ' assign a line number to line[0], which is replace the -1 with a line number. index is the line number so index += 1 increments the number by adding 1.
                                            if line[1].startswith('[') or line[1].startswith(item + ' = '):
                                                line[0] = index
                                                index += 1
                                # Index the remaining keys.
                                for line in lines:
                                    if line[0] == -1:
                                        line[0] = index
                                        index += 1
                                # Sort by index.
                                # Sorting the list of lists lines by the first element [0]. lambda is like a nameless function. The sort will look at example [[2, 'Line 2'], [1, 'Line 1']] so it sees the 1 and shifts it into 1st place and then 2 for 2nd place. This gets the list into the order that is wanted.
                                lines.sort(key=lambda x: x[0])
                                # Create text from lines.
                                text = ''
                                for line in lines:
                                    text += line[1] + '\n'
                                return text
                            # __name__ is the name of the running script. If named __main__, run the following code.
                            # ini_reindex() is the function call and the returned value is saved in text. If the text returned is not an empty string, then call editor.setText(text) to replace edit pane contents with the value of text.
                            if __name__ == '__main__':
                                text = ini_reindex()
                                if text != '':
                            And the Standalone recursive Python Script :
                            import glob
                            # Start processing each 'song.ini' file.
                            print('file:')
                            # for file in glob.iglob('song.ini'): # This will do 'song.ini' in current directorie.
                            for file in glob.iglob(r'**\song.ini', recursive=True): # This will do 'song.ini' in current and subdirectories.
                                print(' ', file)
                                # Read the 'song.ini' file and create a list of indexed lines.
                                with open(file, 'r', encoding='utf8') as r:
                                    lines = [[-1, line.replace('\n', '')] for line in r]
                                    for line in lines:
                                            break
                                    else:
                                index = 0
                                    for line in lines:
                                        if line[0] == -1:
                                                line[0] = index
                                                index += 1
                                for line in lines:
                                    if line[0] == -1:
                                        line[0] = index
                                        index += 1
                                # Sort by index.
                                # Save 'song.ini' file.
                                with open(file, 'w', encoding='utf8') as w:
                                    for line in lines:
                                        w.write(line[1] + '\n')
                            print('done')
                              See how long a discussion thread can go on when the problem statement is imprecise? I don’t know that it really is precise yet. Here’s how I see the problem:
                              If lines starting with these items are present, move them to the top, and put them in this exact order:
                              name =
                              artist =
                              album =
                              genre =
                              year =
                              track =
                              loading_phrase =
                              charter =
                              frets =
                              song_length =
                              icon =
                              If they are not present, make them present but be empty, e.g. frets = and then nothing following.
                              For any other lines, leave them as they are after the icon = line in the output.
                                @alan-kilborn I’m sorry again. I try to do my best…
                                Your formulation is perfect.
                                Just a detail, ‘icon =’ is not important for me. So :
                                For any other lines, leave them as they are after the ‘song_length =’ line in the output.
