    help with find and replace (wildcards)
    3 Posts 2 Posters 19.4k Views 2 Watching
    • Light PortalL Offline
      Light Portal
      Hello, I am repairing some .srt files (subtitles for movies), but it’s tricky. Many different formats.
      In text below, for example, I want to be rid of all {\pos(XXX,XXX.XXX), but I don’t know how to make that in notepad. I tried the wildcards of word and vba, no cigar.
      00:00:14,790 --> 00:00:21,770
      {\pos(201.778,26.666)}战舰波将金号
      12
      00:00:21,770 --> 00:00:25,200
      {\pos(196,170.857)}高斯影业第一制片厂 出品
      13
      00:00:25,200 --> 00:00:28,630
      {\pos(196,195.857)}监制 J·M·布里奥克
      14
      00:00:28,630 --> 00:00:32,180
      {\pos(199,207.857)}编剧
      N·F·阿加兹汉诺瓦·夏科
      15
      00:00:32,190 --> 00:00:38,690
      {\pos(196,225)}导演 S·M·爱森斯坦
      副导演 G·亚力克山德罗夫人
        PeterJones @Light Portal
        @light-portal said in help with find and replace (wildcards):
        Notepad++ does not use Word wildcards or VBA wildcards. It uses a flavor of regular expression (wildcards) known as “Boost regex”. This is documented in the official Notepad++ documentation, which can easily be found through the ? menu in Notepad++, in the entry called Notepad++ Online User Manual. There, you will see a whole page on Searching, with a section on Regular Expressions
        Specifically, in the Find/Replae dialog, you will need to enable the SEARCH MODE = Regular Expression to enable the wildcard feature.
        If i were you, I would search for FIND = {\\pos.*?}. The \\ is used because \ has special meaning to regex, so you need it twice to “escape” it. The .*? means “find 0 or more characters, as few as possible”, so putting it between the pos and the } means it will find up to the first } after the pos. The REPLACE would be blank, because you just want to delete those.
        Useful References
        • Please Read Before Posting
        • FAQ: Where to find regular expressions (regex) documentation
        Light PortalL 1 Reply Last reply Reply Quote 2
          Light Portal @PeterJones
          @peterjones thank you
