    Autocomplete Items Order Issue
    35 Posts 6 Posters 21.5k Views 3 Watching
    • Valery BogomolovV Offline
      Valery Bogomolov @PeterJones
      @peterjones I’m sorry for the “snippet-abuse”, I just wanted to get the most from the Npp’s auto-complete interface. I experimented with autocomplete a lot before developing the parser that generates KeyWords for my favorite language PHP. I wrote about it here
      Unexpectedly, I figured out that I was able, for example, to write faster SQL queries code rather than using any other editor for that.
      FingerText is not compatible with my configured Notepad++, QuickText is not convenient for me to use, but I use it. NppSnippets is a great plugin, but I have to search for a specific item in a dialog to insert a snippet and it takes some time.
      Regards.
      Michael VincentM Alan KilbornA 2 Replies Last reply Reply Quote 0
      • Michael VincentM Online
        Michael Vincent @Valery Bogomolov
        @valery-bogomolov
        You can try the pull request AppVeyor build by downloading, and replacing your current notepad++.exe with the appropriate downloaded, renamed version. Of course, save your current notepad++.exe (notepad++.exe.orig) so you can revert back when done testing.
        Cheers.
        Valery BogomolovV 1 Reply Last reply Reply Quote 3
        • Alan KilbornA Online
          Alan Kilborn @Valery Bogomolov
          @valery-bogomolov
          @michael-vincent said in Autocomplete Items Order Issue:
          You can try the…
          More details (if you need them) on exactly how you’d do that are HERE.
            Valery Bogomolov @Michael Vincent
            @michael-vincent Thank you for the great work, but personally, I don’t like the new UX of the autocomplete: the fx icon is really distracting and I have to look down a couple of lines to see the first result. I would prefer to have the old autocomplete if it could be possible, sorry
              @valery-bogomolov said in Autocomplete Items Order Issue:
              Assuming that means is sorts as you expect now?
              Valery BogomolovV 2 Replies Last reply Reply Quote 1
                  @michael-vincent Ok, now it works. I compared it with the old autocomplete version and the results seem to be the same.
                  Only fx icon is everywhere. There is a func="yes", or func="no" attribute in XML that describes the KeyWord, and the func attribute is not always required. There could be some language expression like return, but it’s not fx, right?
                  Best regards.
                    @valery-bogomolov
                    The “fx” distinguishes the option comes from an autocomplete/*.xml file versus a word from the current file when both word and API autocomplete is active.
                    Scintilla autocomplete has a lot to be desired and Notepad++ does the best it can with it, but plugins can use autocomplete too (e.g., QuickText, TagLEET, I have PythonScripts that do it to provide Python-IDE-like features with jedi). Only you can’t merge the lists - only 1 autocomplete is active at any time. So which suggestion is coming from what source?
                    TagLEET global tags file:
                    TagLEET local tags file:
                    QuickText:
                    PythonScript custom Python IDE:
                    It’d be nice to see them all in the same list, but alas, each time a character is typed and a best match is found, whatever Notepad++ / Plugin matches best displays it’s abbreviated list. The Icons help determine where in the heck this suggestion is coming from.
                    This is no different than most other editors that offer autocomplete (VS Code example)
                    Cheers.
                    • Lycan ThropeL Offline
                      Lycan Thrope
                        Lycan Thrope
                        @michael-vincent ,
                        Okay, to differentiate which is document words and which are autocomplete words seems to make sense, unless you factor in that if you don’t want the words from the document being introduced and only use it for the autocomplete list, the fx is actually redundant to that purpose. Now, if you want to show an icon for words from the document, that triggers if you switch that option on, that makes more sense. Since if the word is from an autocomplete it won’t matter, it’s a different procedure for you to autocomplete a function, and the keyword is just that, so you select it whether it has been in the document previously or not, but if it’s only from the document, that would make more sense to highlight that with a different character glyph. Just my two cents worth. :)
                        Wow, forum is slow and double posting posts. :(
                          @michael-vincent fx means function of x in math… I would use something from what Notepad++ already has in its UI. For example, the cube icon from the Function List panel with light grey color, so not to distract the user and black color for the font in results, as it has right now :)
                          The example icon from the Function List panel
                          and I would prefer to use unicode character instead of png, so it could be scalable and faster to load :)
                          P.s.: btw, I have also issue with NppGTags autocomplete as it shows me gibberish in results. It’s my favorite plugin :( Maybe, the engoding of generated tags file is wrong… no ideas how to fix
                          Cheers.
                          Michael VincentM P 2 Replies Last reply Reply Quote 1
                            I did:
                            No characters, it’s not a PNG. Scintilla has only 2 options.
                            I would contact the author @pnedev and open an issue. He’s been very responsive fixing the Compare Plugin.
                            Cheers.
                              Alan Kilborn @Michael Vincent
                              @michael-vincent
                              My function list icon looks like this, not yours:
                                Michael Vincent @Alan Kilborn
                                @alan-kilborn said in Autocomplete Items Order Issue:
                                You’ll need to restart Notepad++.
                                • P Offline
                                  pnedev @Valery Bogomolov
                                  @valery-bogomolov ,
                                  This thread is becoming rather mixed-up.
                                  Please open an issue in NppGTags repo to discuss its autocomplete problem there.
                                  At first look it seems that the parser you are using (GTags maybe) is not recognizing some symbols in your codebase. AFAIR, the parser won’t be able to parse Unicode right if you are using it.
