    Merge column-mode and multi-edit
    4 Posts 2 Posters 923 Views 1 Watching
    • Bernhard EgeB Offline
      Bernhard Ege
      I sometime need to edit similar lines the same way, e.g.
      foo bar baz
      fofo baba bzbz
      etc…
      to e.g.
      $foo, $bar $baz;
      $fofo, $baba, $bzbz;
      etc.
      I can use colum mode to select the lines which gives me a cursor at the start of each line. But after having inserted the $, I need to move to the end of the word and the distance varies. I would normally use ctrl->right key to move over the word, but this unselects the block and only takes the last position and moves from there.
      In multi-edit mode, I can click on the start of each line and then edit normally, but on several lines at the same time, which is what I want. But having to ctrl-click at the start of each line is very tedious.
      Is there a way to make column mode behave more like multi-edit?
      Or is there a way to mark the editing start points for multi-edit mode in a simple way without using the mouse?
        Ekopalypse @Bernhard Ege
        @bernhard-ege
        If I understand your problem correctly, the answer is:
        Yes, install the plugin BetterMultiSelection via the plugin admin dialog.
        Bernhard EgeB 1 Reply Last reply Reply Quote 6
          Bernhard Ege @Ekopalypse
          @ekopalypse Perfect! This does exactly what I want. Thank you. :)
            @bernhard-ege
            Happy to help.
