    CSVQuery doesn't work with Notepad++ 64 bit?
    3 Posts 2 Posters 1.6k Views 1 Watching
    • Lawrence MyersL Offline
      Lawrence Myers
      CSVQuery doesn’t work with Notepad++ 64 bit?
      The Directory is in the plugin directory. Any suggestions?
        Terry R @Lawrence Myers
        @lawrence-myers said in CSVQuery doesn't work with Notepad++ 64 bit?:
        It would be helpful if you were to supply the version number of your Notepad++ installation, see this post.
        If using the latest version you may be seeing the situation where lots of plugins no longer work, see this announcement.
        If so, then either you have to wait until the CSVQuery plugin is updated to work with the latest version, or downgrade your Notepad++ installation so you can continue working.
        T 1 Reply Last reply Reply Quote 2
          Terry R @Terry R
          @terry-r said in CSVQuery doesn't work with Notepad++ 64 bit?:
          A quick search of this forum found this post. So it appears the CSVQuery plugin hasn’t been updated for the latest version of Notepad++. However there appears to be another plugin which may fill the gap. Have a read.
