    Insert sequential numbers at start of lines
    32 Posts 6 Posters 32.7k Views 2 Watching
    • Ionut DorinI Offline
      Ionut Dorin @Alan Kilborn
      1: Line content
      2: Line content
      3: Line content
      4: Line content
      5: Line content
      6: Line content
      7: Line content
      8: Line content
      9: Line content
      10: Line content
      11: Line content
      12: Line content
      … and to become
      Line content
      Line content
      Line content
      Line content
      etc.
      Find: ^\d+: doesn’t work and plus, i don’t need it for the whole document, just for the lines i select.
        Alan Kilborn @Ionut Dorin
        @Ionut-Dorin said in Insert sequential numbers at start of lines:
        If you did exactly what I said to do, I see no reason why it wouldn’t work on your sample data.
        Ok, so don’t checkmark Wrap around but make your selection first and then checkmark In selection.
        Ionut DorinI 1 Reply Last reply Reply Quote 2
          @Alan-Kilborn Yes, that did it, I think i read too fast and didn’t see that you said “Search mode: Regular expression” and i didn’t check that, so maybe that’s why it didnt work.
          Also, i turned it into a macro for ease of use.
          Thank you so much for your help and patience, you’re a lifesaver.
          • deleeleeD Offline
            deleelee @Alan Kilborn
            @Alan-Kilborn said in Insert sequential numbers at start of lines:
            Sure, most anything is possible with programming.
            Hi Alan, the scripts have been working really well, thank you so much for your help. One thing I’ve noticed is that, when using the script for selected lines, it has to be a block selection for the script to work. I can’t select individual lines (eg: line 1, line 4, line 7) and insert numbers at that the start of only those lines.
            I’ve tried:
            1. Multi-selection using Ctrl + single-click at the start of each line.
            2. Multi-selection using Ctrl + single-click at the start and end of each line.
            3. Multi-selection using Ctrl + double-click to select the first word of each line.
            Numbers 1 & 2 don’t actually select any text so when I run the script I get a “No text selected” message.
            Number 3 only places a number at the start of the line for the last word I select.
            Is it possible or am I expecting more than the script can achieve?
              Alan Kilborn @deleelee
              @deleelee
              You must be referring to the TextFxInsertLineNumbers.py script, because the other script discussed in this topic, InsertLineNumbersOnLines.py, doesn’t deal with any selected text at all.
              Here’s a modified version of the script I’m calling TextFxInsertLineNumbers2.py :
              # -*- coding: utf-8 -*-
              # references:
              #  https://community.notepad-plus-plus.org/topic/23206/insert-sequential-numbers-at-start-of-lines
              #  https://community.notepad-plus-plus.org/topic/23166/faq-desk-how-do-i-replicate-the-features-of-textfx
              from Npp import *
              class TFILN2(object):
                  def __init__(self):
                      handled_line_nbr_list = []
                      running_line_nbr = 1
                      line_tup_list = []
                      for s in range(editor.getSelections()):
                          start_line = editor.lineFromPosition(editor.getSelectionNStart(s))
                          end_line = editor.lineFromPosition(editor.getSelectionNEnd(s))
                          line_tup_list.append((start_line, end_line))
                          line_tup_list.sort()
                      for (start_line, end_line) in line_tup_list:
                          for line_nbr in range(start_line, end_line + 1):
                              if line_nbr not in handled_line_nbr_list:
                                  line_content = editor.getLine(line_nbr).rstrip('\n\r')
                                  editor.replaceLine(line_nbr, '{n:08} {c}'.format(n=running_line_nbr, c=line_content))
                                  running_line_nbr += 1
                                  handled_line_nbr_list.append(line_nbr)
                      editor.setSel(editor.getCurrentPos(), editor.getCurrentPos())
              if __name__ == '__main__': TFILN2()
              This version handles all types of selections.
              deleeleeD 2 Replies Last reply Reply Quote 2
              • deleeleeD Offline
                Perfect!!! Thank you so much 😁👍
                • deleeleeD Offline
                  # references:
                  from Npp import *
                      def __init__(self):
                          line_tup_list = []
                  Hi Alan, I absolutely love this script, thank you, and I use it regularly. How would I adapt it so that instead of inserting sequential numbers, it inserts sequential letters? ie: lines begin with a) b) c) etc.
                    @deleelee said in Insert sequential numbers at start of lines:
                    Well, this is “dicey” as you quickly run out of letters.
                    Typically, you only have a-z, i.e., 26.
                    So, if you’re only going to run the script on very small files, you could hack the line_list2.append( line to be:
                    line_list2.append('{n}) {c}'.format(n=chr(97+line_nbr), c=line_content))
                    But note, this is a real hack, as there’s no check for too many lines.
                    deleeleeD 1 Reply Last reply Reply Quote 2
                    • Mark OlsonM Offline
                      Mark Olson
                      If you wanted to not run out of letters, by simply increasing the number of letters by 1 every time to get to z (thus aa would follow z and aaa would follow zz), you could use the code:
                      num_chars, offset = divmod(line_nbr, 26)
                      line_list2.append( ( ( num_chars + 1 ) * chr(offset + 97) ) + line_content)
                      Note that I haven’t actually executed this code as written.
                      • deleeleeD Offline
                        Thanks Alan. That had me confused until I realised you weren’t referring to the script I quoted which was TextFxInsertLineNumbers2.py and it doesn’t have line_list2.append. Is it possible to adapt that script? The one you’ve referred to seems to be TextFxInsertLineNumbers.py and I don’t use that.
                          @deleelee
                          Hmm, you’re right, I guess I ignored the script you quoted, and just looked in this thread for the first script presented. Sorry.
                          Anyway, that script has a similar line:
                          and I’d think it wouldn’t be that hard to adapt that line from what I gave before, into:
                          editor.replaceLine(line_nbr, '{n}) {c}'.format(n=chr(96+running_line_nbr), c=line_content))
                          deleeleeD 1 Reply Last reply Reply Quote 1
                          • deleeleeD Offline
                            Thank you! I had tried editing that line myself but I didn’t quite get it right. It’s all good now thanks to you 😁
