    keep styles in notepad++ after saving document
    3 Posts 2 Posters 676 Views 1 Watching
    • wilman santiagoW Offline
      wilman santiago
      Dear experts
      How can keep styles in notepad++ after saving document?
      For example : I have selected a text, clic on right=>Style one token=>Using 1st style, and this work fine, however, I close the document and open it newly and not appear the style applied.
      Regards
        Alan Kilborn @wilman santiago
        @wilman-santiago said in keep styles in notepad++ after saving document:
        Right now you cannot do this natively.
        However, the author of Notepad++ recently expressed interest himself in such a feature (see HERE), so it is very possible you will be able to do this soon in Notepad++.
        wilman santiagoW 1 Reply Last reply Reply Quote 2
          wilman santiago @Alan Kilborn
          How can get this “To store the info of styled tokens, the intuitive & efficient way is using offset/length.”?
