    help to clean document
    3 Posts 2 Posters 494 Views 1 Watching
    • pinuzzu99P Offline
      pinuzzu99
      hi there,
      from multi line document like this:
      ZmVjdGVkdf44XNob3cta/G9zdGVkLWJ5-LXNhbS1kaXZpbmU-240323?in=defectsets/dewect" primary sc-font-light">guess - 24.03.21</a>
      9udC1saWdodCI+RGVmZWN0ZWQg_mFkaW8gU2hvdyBIb3N0ZW-170323?in=decords/sets/defec-trackTitle2MtZ-class="trackItem 17.03.23</a>
      VmZW345des435ggfWQg_mFkaW8gU2h-show-host-alsthej-100323?in=records/sems/deeds2-wdrfgse-raxo" class="trackItem_2>
      i need to clean to have this one:
      now with regex i use this command to clean my document:
      find: in=.*.
      replace: empty
      then:
      find: ?
      replace: empty
      i need 2 steps because with ?in=.*. np++ recognizes ? as variable and not just as text
      so, is there a way to delete all values from ? to the end of line ?
        Ekopalypse @pinuzzu99
        @pinuzzu99 said in help to clean document:
        9udC1saWdodCI+RGVmZWN0ZWQg_mFkaW8gU2hvdyBIb3N0ZW-170323?in=decords/sets/defec-trackTitle2MtZ-class=“trackItem 17.03.23</a>
        VmZW345des435ggfWQg_mFkaW8gU2h-show-host-alsthej-100323?in=records/sems/deeds2-wdrfgse-raxo” class="trackItem_2>
        To search literally for ?, you must escape it, like: \?in=.*
          pinuzzu99
          oh yes, it work fine.
          thank you for reply
          Regards
