    Little Dialog-wrapper for PythonScript
    74 Posts 8 Posters 82.7k Views 2 Watching
      Ekopalypse @Michael Vincent
      @Michael-Vincent
      Hi, I have quite a lot on my plate privately at the moment, but I promise to upload a new version this weekend.
      It’s actually going quite well and if you stick to what’s currently implemented, there shouldn’t be any difficulties. Sorry for the delays.
        @Michael-Vincent
        Repo has been updated, but be warned that I’m not completely satisfied yet, which means it’s not API stable. Further updates could break things that currently work.
          Ekopalypse @Ekopalypse
          @Michael-Vincent
          There was a typo that prevented the dialog from being created.
          I should have tested it before, sorry. Is fixed now.
          • Michael VincentM Offline
            Michael Vincent @Ekopalypse
            @Ekopalypse
            Great! I have my small example:
            from WinDialog import Button, Dialog, CheckBoxButton, Label, TextBox
            from WinDialog.controls.button import BM, BST
            from WinDialog.win_helper import SendMessage
            user_input = ''
            REGEX      = True
            IGNORECASE = True
            class FilerLinesEditDlg(Dialog):
                def __init__(self):
                    super().__init__(            title='Filter Lines Editing', size=(250, 75), center = True)
                    self.label  = Label(         title='Filter for:'         , position=(10, 12),  size=(30, 11) )
                    self.edit   = TextBox(                                     position=(45, 10),  size=(195, 14) )
                    self.case   = CheckBoxButton(title='Case Sensitive'      , position=(45, 30),  size=(80, 14)  )
                    self.regex  = CheckBoxButton(title='Regular Expression'  , position=(145, 30), size=(80, 14)  )
                    self.ok     = Button(        title='OK'                  , position=(130, 55), size=(50, 11)  )
                    self.cancel = Button(        title='Cancel'              , position=(187, 55), size=(50, 11)  )
                    self.ok.on_click     = self.on_ok
                    self.cancel.on_click = self.on_cancel
                    self.case.on_click   = self.on_case
                    self.regex.on_click  = self.on_regex
                    self.show()
                def initialize(self):
                    global IGNORECASE
                    global REGEX
                    SendMessage(self.case.hwnd, BM.SETCHECK, IGNORECASE, 0)
                    SendMessage(self.regex.hwnd, BM.SETCHECK, REGEX, 0)
                def on_ok(self):
                    global user_input
                    user_input = self.edit.get_text()
                    self.terminate()
                def on_cancel(self):
                    global user_input
                    user_input = None
                    self.terminate()
                def on_case(self):
                    global IGNORECASE
                    check = SendMessage(self.case.hwnd, BM.GETCHECK, 0, 0)
                    if check & BST.CHECKED:
                        IGNORECASE = True
                    else:
                        IGNORECASE = False
                def on_regex(self):
                    global REGEX
                    check = SendMessage(self.regex.hwnd, BM.GETCHECK, 0, 0)
                        REGEX = True
                    else:
                        REGEX = False
            FilerLinesEditDlg()
            print(f"User:  {user_input}")
            print(f"Case:  {IGNORECASE}")
            print(f"Regex: {REGEX}")
            It seems to run correctly and prints status to the PythonScript console. I plan to integrate this into a larger script.
            I’m not sure I did the checkbox stuff correctly. It works, but I had to import some extra classes and the SendMessage function from your helper library. Did I do this right?
            Cheers.
              @Michael-Vincent
              You can do it this way, but I personally would put the globals as attributes in the class to avoid globals in the first place.
              For the GETCHECK, because the checkbox is a “boolean” value, I would do something like: …
                  def on_case(self):
                      self.IGNORECASE = not self.IGNORECASE
              dlg = FilerLinesEditDlg()
              print(f"User:  {dlg.user_input}")
              print(f"Case:  {dlg.IGNORECASE}")
              print(f"Regex: {dlg.REGEX}")
              As for the SETCHECK, the SendMessage function is currently required.
              The next version, uploaded this weekend, will have a checkbox button method setCheckState (that’s the same kind of naming PS does … so it seems to make the most sense, right?). And now that I think about it, getCheckState makes sense too because of the 3-state checkboxes. Also, the next version will be able to handle IDOK and IDCANCEL, which means you can close a dialog with ESC and trigger the execution of the edit with ENTER.
              Michael VincentM 1 Reply Last reply Reply Quote 3
                @Ekopalypse said in Little Dialog-wrapper for PythonScript:
                This just keeps getting better!
                I updated the globals to a return class that I pass in and then examine on output. The issue is I want this as a prompt in a larger already existing PythonScript and class so the “globals” are just globals in this example - in my project, they are attributes of the existing class that the dialog will need to know to set on startup and then return in case of modifications in the dialog. The globals were just a “cheat” way to illustrate a “complete self-contained example” to post here. But point taken - I am avoiding globals in the finished product.
                The on_case recommendation works as well very nicely and certainly simplifies code - removes the need for me obtaining BM.GETCHECK as well.
                It’s Memorial Day weekend in the States so I’ll be stepping away from all this for the long weekend. I do hope you take time to relax this - and any weekend for that matter. I’m in no rush for the updates, but will keep checking back the repo to see when they in fact do arrive.
                UPDATE:
                The updated script from above with fixes discussed. Also add the c#_ prefixes to the controls to force the TABSTOP order - seems to be alphabetical:
                from Npp import editor
                from WinDialog import Button, CheckBoxButton, DefaultButton, Dialog, Label, TextBox
                class Returns(object):
                    def __init__(self, U=None, I=False, R=False):
                        self.user_input = U
                        self.IGNORECASE = I
                        self.REGEX      = R
                    def __init__(self, ret=Returns()):
                        super().__init__(               title='Filter Lines Editing', center = True,      size=(250, 75) )
                        self.c2_edit   = TextBox(                                     position=(45, 10),  size=(195, 14) )
                        self.c3_case   = CheckBoxButton(title='Case Sensitive'      , position=(45, 30),  size=(80, 14)  )
                        self.c4_regex  = CheckBoxButton(title='Regular Expression'  , position=(145, 30), size=(80, 14)  )
                        self.c1_ok     = DefaultButton( title='OK'                  , position=(130, 55), size=(50, 11)  )
                        self.c5_cancel = Button(        title='Cancel'              , position=(187, 55), size=(50, 11)  )
                        self.ret = ret
                        self.c1_ok.on_click     = self.on_ok
                        self.c5_cancel.on_click = self.on_cancel
                        self.c3_case.on_click   = self.on_case
                        self.c4_regex.on_click  = self.on_regex
                        self.show()
                        self.c2_edit.set_text(self.ret.user_input)
                        SendMessage(self.c3_case.hwnd,  BM.SETCHECK, self.ret.IGNORECASE, 0)
                        SendMessage(self.c4_regex.hwnd, BM.SETCHECK, self.ret.REGEX, 0)
                    def on_ok(self):
                        self.ret.user_input = self.c2_edit.get_text()
                        self.terminate()
                        self.ret.user_input = None
                        self.terminate()
                    def on_case(self):
                        self.ret.IGNORECASE = not self.ret.IGNORECASE
                    def on_regex(self):
                        self.ret.REGEX = not self.ret.REGEX
                user_input = editor.getSelText()
                IGNORECASE = False
                REGEX      = True
                #-----vvvv-----
                ret        = Returns(user_input, IGNORECASE, REGEX)
                FilerLinesEditDlg(ret)
                user_input = ret.user_input
                IGNORECASE = ret.IGNORECASE
                REGEX      = ret.REGEX
                if ret.user_input is None:
                    print("EXIT")
                else:
                Cheers.
                EkopalypseE Alan KilbornA 3 Replies Last reply Reply Quote 3
                  @Michael-Vincent
                  Don’t worry, the weekends are for family commitments. I’ll just publish what I’ve managed to do during the week.
                  As for the WS_TABSTOP, I thought that the order of creation of the controls determines the order … I’ll have to check that.
                    Alan Kilborn @Michael Vincent
                    @Michael-Vincent said in Little Dialog-wrapper for PythonScript:
                    Confused me at first; I’m wondering what the heck C# has to do with this…
                    Finally I notice this is what you meant:
                      @Michael-Vincent
                      The issue is here. dir always returns a sorted list.
                      Replacing it with for item in self.__dict__.keys(): seems to behave as expected. The first control created that has the style ws_tabstop gets the initial focus.
                        First beta version released.
                        Sorry for breaking existing code, but from now on this should not happen.
                        The current state of the project is what I currently support.
                        If you encounter issues where the dialog box or controls do not work as described or advertised,
                        please report them by submitting a “git issue”. I will diligently investigate the issue and work on a solution.
                        However, please note that any requests for additional functionality beyond what is currently offered will be considered feature requests.
                        While I appreciate user feedback, I prioritize implementing features that benefit me personally and align with the overall goals of the project,
                        which is to be a simple wrapper over DialogBoxIndirectParam Windows API.
                        Thank you for your understanding."
                          My example script above borrows from @Alan-Kilborn 's filter line editing script and provides a nice GUI to select case insensitive or regular expression type filtering.
                          Here’s a new example, inspired by a script in the jN plugin translate script:
                          import requests
                          from enum import Enum
                          from WinDialog import Button, ComboBox, DefaultButton, Dialog, Label, TextBox
                          from WinDialog.win_helper import WindowStyle as WS
                          TITLE = "Translate"
                          class Languages(Enum):
                              """Translated language options."""
                              Chinese    = "zh"
                              English    = "en"
                              French     = "fr"
                              German     = "de"
                              Italian    = "it"
                              Japanese   = "ja"
                              Portuguese = "pt"
                              Russian    = "ru"
                              Spanish    = "es"
                              """The input / output for the Translator service."""
                              def __init__(self, text="", srclang="English", dstlang="English"):
                                  self.text = text
                                  self.trans = ""
                                  self.srclang = srclang
                                  self.dstlang = dstlang
                          class Translator(Dialog):
                              """A Translator dialog interface."""
                                  super().__init__(               title=TITLE         , center = True      , size=(250, 140) )
                                  self.translate = DefaultButton( title='&Translate'  , position=(80, 120), size=(50, 11)  )
                                  self.label1    = Label(         title='Text:'       , position=(10, 12)  , size=(35, 11)  )
                                  self.text      = TextBox(                             position=(45, 10)  , size=(195, 44) )
                                  self.swapt     = Button(        title='^&v'         , position=(20, 55)  , size=(20, 14)  )
                                  self.srclang   = ComboBox(                            position=(45, 56)  , size=(80, 14)  )
                                  self.swapl     = Button(        title='<&=>'        , position=(132, 55) , size=(20, 14)  )
                                  self.dstlang   = ComboBox(                            position=(160, 56) , size=(80, 14)  )
                                  self.label2    = Label(         title='Translated:' , position=(10, 72)  , size=(35, 11)  )
                                  self.trans     = TextBox(                             position=(45, 70)  , size=(195, 44) )
                                  self.replace   = Button(        title='&Replace'    , position=(135, 120) , size=(50, 11)  )
                                  self.close     = Button(        title='&Close'      , position=(190, 120), size=(50, 11)  )
                                  self.ret = ret
                                  self.onIdOk             = self.on_translate
                                  self.translate.onClick  = self.on_translate
                                  self.swapt.onClick      = self.on_swapt
                                  self.swapl.onClick      = self.on_swapl
                                  self.dstlang.onSelEndOk = self.on_translate
                                  self.replace.onClick    = self.on_replace
                                  self.close.onClick      = self.on_close
                                  self.srclang.style = self.dstlang.style | WS.TABSTOP
                                  self.dstlang.style = self.dstlang.style | WS.TABSTOP
                                  self.show()
                                  """Initialize the dialog."""
                                  self.text.setText(self.ret.text)
                                  self._init_langs()
                              def _init_langs(self):
                                  srclang = list(n.name for n in Languages)
                                  if self.ret.srclang in srclang:
                                      srclang.insert(0, self.ret.srclang)
                                  self.srclang.set(srclang)
                                  dstlang = list(n.name for n in Languages)
                                  if self.ret.dstlang in dstlang:
                                      dstlang.insert(0, self.ret.dstlang)
                                  self.dstlang.set(dstlang)
                              def on_translate(self):
                                  """Translate the text."""
                                  text_encoded = requests.utils.quote(self.text.getText())
                                  srclang = Languages[self.srclang.getSelectedItemText()]
                                  dstlang = Languages[self.dstlang.getSelectedItemText()]
                                  # Set return languages
                                  self.ret.srclang = srclang.name
                                  self.ret.dstlang = dstlang.name
                                  srccode = srclang.value
                                  dstcode = dstlang.value
                                  # EXAMPLE: LANGPAIR=EN|IT USING 2 LETTER ISO OR RFC3066 LIKE ZH-CN
                                  langpair = f"{srccode}|{dstcode}"
                                  r = requests.get(f"http://mymemory.translated.net/api/get?q={text_encoded}&langpair={langpair}")
                                  response = r.json()['responseData']['translatedText']
                                  # Set return translation
                                  if response is not None:
                                      self.ret.trans = response
                                  else:
                                      self.ret.trans = "(no translation found)"
                                  self.trans.setText(self.ret.trans)
                                  # Set return text
                                  self.ret.text = self.text.getText()
                              def on_swapl(self):
                                  """Swap languages."""
                                  self.ret.dstlang = self.srclang.getSelectedItemText()
                                  self.ret.srclang = self.dstlang.getSelectedItemText()
                                  self._init_langs()
                              def on_swapt(self):
                                  """Swap texts."""
                                  self.ret.trans = self.text.getText()
                                  self.ret.text  = self.trans.getText()
                              def on_replace(self):
                                  """Replace text with translation in document."""
                                  if self.ret.trans != "":
                                      editor.replaceSel(self.ret.trans)
                                      self.terminate()
                              def on_close(self):
                                  """Close dialog."""
                                  self.terminate()
                          class Translate():
                              A translator service.
                              def __init__(self):
                                  self.text    = ""
                                  self.trans   = ""
                                  self.srclang = "English"
                                  self.dstlang = "English"
                              def translate(self):
                                  text = editor.getSelText()
                                  if text is not None:
                                      self.text = text
                                  ret = Returns(self.text, self.srclang, self.dstlang)
                                  Translator(ret)
                                  self.text    = ret.text
                                  self.trans   = ret.trans
                                  self.srclang = ret.srclang
                                  self.dstlang = ret.dstlang
                          if __name__ == '__main__':
                              try:
                                  isinstance(translate, Translate)
                                  # print("Translator `translate' already enabled")
                              except NameError:
                                  translate = Translate()
                              translate.translate()
                          Cheers.
                            Michael Vincent @Michael Vincent
                            And a dictionary as well:
                            import requests
                            from WinDialog import Button, DefaultButton, Dialog, Label, ListBox, TextBox
                            TITLE = "Dictionary"
                                """The input / output for the Dictionary service."""
                                def __init__(self, word=""):
                                    self.word = word
                                    self.definition = ""
                                    self.synonyms = []
                                    self.antonyms = []
                                    self.replace = None
                            class Dictionary(Dialog):
                                """A Dictionary dialog interface."""
                                    super().__init__(                title=TITLE      , center = True      , size=(220, 250))
                                    self.word       = TextBox(                          position=(10, 12)  , size=(150, 14) )
                                    self.lookup     = DefaultButton( title='&Lookup'  , position=(165, 13) , size=(45, 11)  )
                                    self.definition = TextBox(                          position=(10, 30)  , size=(200, 100))
                                    self.label1     = Label(         title='Synonyms' , position=(10, 140) , size=(45, 11)  )
                                    self.synonyms   = ListBox(                          position=(10, 155) , size=(90, 65)  )
                                    self.replsyn    = Button(        title='Re&place' , position=(10, 220),  size=(45, 11)  )
                                    self.label2     = Label(         title='Antonyms' , position=(120, 140), size=(45, 11)  )
                                    self.antonyms   = ListBox(                          position=(120, 155), size=(90, 65)  )
                                    self.replant    = Button(        title='Repl&ace' , position=(120, 220), size=(45, 11)  )
                                    self.close      = Button(        title='&Close'   , position=(165, 235), size=(45, 11)  )
                                    self.ret = ret
                                    self.onIdOk          = self.on_lookup
                                    self.lookup.onClick  = self.on_lookup
                                    self.replsyn.onClick = self.on_replace_syn
                                    self.replant.onClick = self.on_replace_ant
                                    self.definition.style = self.definition.style | WS.VSCROLL | WS.HSCROLL # | WS.DISABLED
                                    self.synonyms.style   = self.synonyms.style   | WS.TABSTOP
                                    self.antonyms.style   = self.antonyms.style   | WS.TABSTOP
                                    self.show()
                                def _initialize(self):
                                    self.ret = Returns(self.ret.word)
                                    self.word.setText(self.ret.word)
                                    self.synonyms.clear()
                                    self.antonyms.clear()
                                    self._on_lookup()
                                def _on_lookup(self):
                                    """Lookup the word."""
                                    self._initialize()
                                    text_encoded = requests.utils.quote(self.word.getText())
                                    r = requests.get(f"http://api.dictionaryapi.dev/api/v2/entries/en/{text_encoded}")
                                    if r.status_code != 200:
                                        return
                                    synonyms = []
                                    antonyms = []
                                    response = ""
                                    for idx, defs in enumerate(r.json()[0]['meanings']):
                                        response += f"{idx+1} : {defs['partOfSpeech']}\r\n"
                                        for pos in defs['definitions']:
                                            response += f"    {pos['definition']}\r\n"
                                            synonyms.extend(pos['synonyms'])
                                            antonyms.extend(pos['antonyms'])
                                        synonyms.extend(defs['synonyms'])
                                        antonyms.extend(defs['antonyms'])
                                    self.ret.definition = response
                                    self.definition.setText(self.ret.definition)
                                    # Need case insensitive since ListBox has style SORT, which is case insensitive
                                    self.ret.synonyms = sorted(set(synonyms), key=str.casefold)
                                    self.ret.antonyms = sorted(set(antonyms), key=str.casefold)
                                    self.synonyms.addStrings(self.ret.synonyms)
                                    self.antonyms.addStrings(self.ret.antonyms)
                                def on_lookup(self):
                                    self.ret.word = self.word.getText()
                                    self._on_lookup()
                                def on_replace_syn(self):
                                    item = self.synonyms.getSelectedItem()
                                    if item < 0:
                                        return
                                    self.ret.replace = self.synonyms._ListBox__items[item].value
                                    editor.replaceSel(self.ret.replace)
                                    self.terminate()
                                def on_replace_ant(self):
                                    item = self.antonyms.getSelectedItem()
                                    if item < 0:
                                        return
                                    self.ret.replace = self.antonyms._ListBox__items[item].value
                                    self.terminate()
                                def on_close(self):
                                    """Close dialog."""
                                    self.terminate()
                            def editor_getWordAtCaretOrSelection():
                                retval = ''
                                (sel_start, sel_end) = (editor.getSelectionStart(), editor.getSelectionEnd())
                                if editor.getSelections() == 1 and sel_start != sel_end:
                                    retval = editor.getTextRange(sel_start, sel_end)
                                else:
                                    start_of_word_pos = editor.wordStartPosition(editor.getCurrentPos(), True)
                                    end_of_word_pos = editor.wordEndPosition(start_of_word_pos, True)
                                    if start_of_word_pos != end_of_word_pos:
                                        retval = editor.getTextRange(start_of_word_pos, end_of_word_pos)
                                        editor.setSelection(end_of_word_pos, start_of_word_pos)
                                return retval
                            def lookup():
                                word = ""
                                if editor.getSelectionEmpty():
                                    word = editor_getWordAtCaretOrSelection()
                                else:
                                    word = editor.getSelText()
                                if len(word) <= 0:
                                    return
                                ret = Returns(word)
                                Dictionary(ret)
                                # print(ret.word)
                                # print(ret.definition)
                                # print(ret.synonyms)
                                # print(ret.antonyms)
                                # print(ret.replace)
                                lookup()
                            Cheers.
                              I’m just starting to experiment with this “Little Dialog wrapper”…
                              nice demo in WinDialog_tests_\test_win_dialog.py
                              Actually, I think, from the screenshot, that it is ...\lib\WinDialog\__tests__\test_button.py that is being run, NOT test_win_dialog.py.
                              When trying either of the two basic examples HERE, I get a dialog that appears and looks like this:
                              But clicking on the Okay button doesn’t print anything to the PS console window (as the code makes me believe it should) and clicking on the Close Dialog button doesn’t close it (only clicking on the X in the upper right corner will end it).
                              I must be doing something wrong in a really basic sense?
                              @Michael-Vincent
                              I tried your recent (August 2023) scripts and both of them failed because they can’t find the import when you do import requests. Probably you are running with Prefer installed Python libraries?
                              I don’t have an “installed” Python, but I have a portable Python 3.11.4. I wonder what it takes to make Notepad++ see and use that…
                              rdipardoR EkopalypseE 2 Replies Last reply Reply Quote 2
                              • rdipardoR Offline
                                rdipardo @Alan Kilborn
                                @Alan-Kilborn said in Little Dialog-wrapper for PythonScript:
                                @Michael-Vincent
                                The builtin urllib.request module should be available to any Python 3 host. You can then do the JSON serialization with the builtin json module. I can’t test it at the moment, but a more portable script would look something like this:
                                -import requests
                                +import json
                                +import urllib.request as requests
                                +import urllib.parse
                                         self._initialize()
                                -        text_encoded = requests.utils.quote(self.word.getText())
                                -        r = requests.get(f"http://api.dictionaryapi.dev/api/v2/entries/en/{text_encoded}")
                                -        if r.status_code != 200:
                                +        text_encoded = urllib.parse.quote(self.word.getText())
                                +        r = requests.urlopen(requests.Request(f"http://api.dictionaryapi.dev/api/v2/entries/en/{text_encoded}"))
                                +        if r.status != 200:
                                +            r.close()
                                             return
                                         synonyms = []
                                         antonyms = []
                                         response = ""
                                -        for idx, defs in enumerate(r.json()[0]['meanings']):
                                +        for idx, defs in enumerate(json.loads(r.read().decode('utf8'))[0]['meanings']):
                                +        r.close()
                                  Ekopalypse @Alan Kilborn
                                  The only thing you did wrong was to assume that once the author changed the public API interface, he would also change the examples in the documentation, but … man … he screwed up :-)
                                  on_click != onClick
                                  Alan KilbornA 2 Replies Last reply Reply Quote 3
                                    Alan Kilborn @Ekopalypse
                                    on_click != onClick
                                    It works better that way. :-)
                                    Probably the code in test_different_ways_to_create_dialogs.py in the __test__ folder needs the same change?
                                    One more oddity: With the aformentioned test_button.py script, I have to press the Close Dialog button TWICE before the script ends.
                                    It seems that the dialog IS closing with the first press, but something is reopening it?
                                      Alan Kilborn @rdipardo
                                      @rdipardo
                                      Your changes did indeed allow the dictionary-lookup script to run for me. Thanks!
                                      For others that might be interested, here’s a full version of Michael Vincent’s dictionary script with rdipardo’s changes:
                                      import json
                                      import urllib.parse
                                              self.word = word
                                              self.synonyms = []
                                              self.antonyms = []
                                              self.replace = None
                                              self.ret = ret
                                              self.show()
                                              self._on_lookup()
                                              self._initialize()
                                              if r.status != 200:
                                                  r.close()
                                                  return
                                              synonyms = []
                                              antonyms = []
                                              response = ""
                                              r.close()
                                              self._on_lookup()
                                              if item < 0:
                                                  return
                                              self.terminate()
                                              if item < 0:
                                                  return
                                              self.terminate()
                                          def on_close(self):
                                              """Close dialog."""
                                              self.terminate()
                                          retval = ''
                                          else:
                                          return retval
                                      def lookup():
                                          word = ""
                                          else:
                                          if len(word) <= 0:
                                              notepad.messageBox('Select a word (or put the caret in a word) before running.', 'Error')
                                              return
                                          ret = Returns(word)
                                          Dictionary(ret)
                                          # print(ret.word)
                                          lookup()
                                      Michael VincentM 1 Reply Last reply Reply Quote 2
                                        @Ekopalypse
                                        Something is definitely up with having to close things twice.
                                        When trying out various scripts from the __test__ folder, e.g. test_progressbar.py, test_statusbar.py, I have to press the X in the upper right of the window TWICE before the script truly ends.
                                          Yeah, lol, apparently my code isn’t really self-explanatory, too bad, was hoping it was.
                                          Each test_{control} script executes once the dialog by rc-generation and once as a class example.
                                            Ha, okay, I wasn’t really digging into any of the code (yet!), just running things like a dumb user (success!) and misunderstanding what results were obtained.
                                            Thanks for the clarification.
                                            What I like to do if I have code that runs two ways is to let it only one way run via a controlling variable at the top. That way someone trying it can change one line (to change the variable) and the rest will run differently.
