    Little Dialog-wrapper for PythonScript
    74 Posts 8 Posters 79.7k Views 2 Watching
      Preview of the PR for enable/disable of controls:
      In __control_template.py, at the bottom, add two member functions to the Control class:
      def enable(self, e : bool) -> bool: return True if WinDLL('user32').EnableWindow(self.hwnd, e) else False
      def isEnabled(self) -> bool: return True if WinDLL('user32').IsWindowEnabled(self.hwnd) else False
      And of course, near the top of the file:
      from ctypes import WinDLL
      • SN-CHS Offline
        SN-CH
        @Ekopalypse, @Alan-Kilborn
        Good afternoon,
        I would appreciate if you could give me a word of advice.
        I wonder if solution of this thread can help me to solve the following task: I need to pass integer argument to the Python script I run in N++ with PythonScript. Does it make sense to use this wrapper or is it an overkill because there is an easier way to do this?
          Alan Kilborn @SN-CH
          @SN-CH
          I need to pass integer argument to the Python script I run… Does it make sense to use this wrapper or is it … overkill because there is an easier way…?
          It sounds like it would be overkill, but only you can judge that.
          About the simplest way to achieve what you are asking for is:
          z = notepad.prompt('prompt text:', 'title bar of window', '')
          if z is not None:
              z = int(z)
              print(z)
          which will give you a (no frills) window to enter your integer into:
          • SN-CHS Offline
            SN-CH
            @Alan-Kilborn said in Little Dialog-wrapper for PythonScript:
            z = notepad.prompt(‘prompt text:’, ‘title bar of window’, ‘’)
            Works perfectly. Much appreciated.
            • Michael VincentM Michael Vincent referenced this topic on
              PeterJones @Ekopalypse
              @Ekopalypse ,
              After reading this post, I wanted to try out @Michael-Vincent’s translation script.
              So I went to my portable that has PythonScript 3.0.17 installed, and tried to install based on the README instructions and tried to run the first example there. I get
              Python 3.12.1 (tags/v3.12.1:2305ca5, Dec  7 2023, 22:03:25) [MSC v.1937 64 bit (AMD64)]
              Initialisation took 406ms
              Ready.
                File "C:\usr\local\apps\npp\npp862.ps3\plugins\Config\PythonScript\scripts\windlg_ex1.py", line 1, in <module>
                  from WinDialog import Dialog, Button, create_dialog_from_rc
              ModuleNotFoundError: No module named 'WinDialog'
              In following the instructions, I put the WinDialog folder in the user directory ...plugins\Config\PythonScript\lib, as instructed. I can verify it’s there:
              > cd plugins
              > dir
               Directory of C:\usr\local\apps\npp\npp862.ps3\plugins
              02/08/2024  01:28 PM    <DIR>          .
              02/08/2024  01:28 PM    <DIR>          ..
              02/08/2024  01:29 PM    <DIR>          ColumnTools
              03/29/2024  09:36 AM    <DIR>          Config
              01/14/2024  03:33 AM    <DIR>          doc
              02/08/2024  01:09 PM    <DIR>          mimeTools
              02/08/2024  01:09 PM    <DIR>          NppConverter
              02/08/2024  01:09 PM    <DIR>          NppExport
              02/08/2024  01:12 PM    <DIR>          PythonScript
              > dir Config
               Directory of C:\usr\local\apps\npp\npp862.ps3\plugins\Config
              03/29/2024  09:36 AM    <DIR>          .
              03/29/2024  09:36 AM    <DIR>          ..
              03/29/2024  10:27 AM               179 ColumnTools.ini
              02/08/2024  01:12 PM               646 converter.ini
              02/08/2024  01:07 PM           208,728 nppPluginList.dll
              03/29/2024  10:23 AM    <DIR>          PythonScript
              > dir Config\PythonScript
               Directory of C:\usr\local\apps\npp\npp862.ps3\plugins\Config\PythonScript
              03/29/2024  10:23 AM    <DIR>          .
              03/29/2024  10:23 AM    <DIR>          ..
              03/29/2024  10:08 AM    <DIR>          lib
              03/29/2024  10:25 AM    <DIR>          scripts
              > dir Config\PythonScript\lib\WinDialog
               Directory of C:\usr\local\apps\npp\npp862.ps3\plugins\Config\PythonScript\lib\WinDialog
              03/29/2024  10:08 AM    <DIR>          .
              03/29/2024  10:08 AM    <DIR>          ..
              03/29/2024  10:08 AM    <DIR>          controls
              03/29/2024  10:08 AM             2,748 readme.md
              03/29/2024  10:08 AM    <DIR>          resource_parser
              03/29/2024  10:08 AM         2,145,865 test_dynamic_dialog2.gif
              03/29/2024  10:08 AM    <DIR>          win_helper
              03/29/2024  10:08 AM            22,893 __init__.py
              03/29/2024  10:08 AM    <DIR>          __tests__
              If I move WinDialog from the user directory to the machine directory (C:\usr\local\apps\npp\npp862.ps3\plugins\PythonScript\lib), then the script can see WinDialog and it loads and runs fine.
              Is there some magic that needs to go in the startup.py to make PS3 see the user-lib directory for a portable installation?
              Debug Info
              Notepad++ v8.6.2   (64-bit)
              Build time : Jan 14 2024 - 02:16:00
              Path : C:\usr\local\apps\npp\npp862.ps3\notepad++.exe
              Command Line :
              Local Conf mode : ON
              Cloud Config : OFF
              OS Version : 22H2
              OS Build : 19045.4170
              Current ANSI codepage : 1252
              Plugins :
                  ColumnTools (1.4.5.1)
                  mimeTools (3)
                  NppConverter (4.5)
                  PythonScript (3.0.17)
              Michael VincentM 2 Replies Last reply Reply Quote 1
              • Michael VincentM Offline
                Michael Vincent @PeterJones
                @PeterJones said in Little Dialog-wrapper for PythonScript:
                PythonScript 3.0.17
                That’s “most likely” the problem. See here:
                https://github.com/bruderstein/PythonScript/issues/322
                I have stayed on 3.0.16 because of this and until this gets fixed.
                Cheers.
                PeterJonesP mpheathM 2 Replies Last reply Reply Quote 4
                  PeterJones @Michael Vincent
                  @Michael-Vincent said in Little Dialog-wrapper for PythonScript:
                  Okay, switching to 8.6.4 portable with 3.0.16, I can get it to work using the user-lib instead of machine-lib. Thanks.
                  update: moved remainder of this post to the other Topic, since it’s translate.py specific, and this Dialog-wrapper Topic is already pretty full…
                  • mpheathM Offline
                    mpheath @Michael Vincent
                    @Michael-Vincent You can add paths to sys.path if want to use PythonScript version 3.0.17.0.
                    This is what I have been using in startup.py .
                    # Fix for sys.path bug in 3.0.17
                    if notepad.getPluginVersion() in ('3.0.17.0',):
                        sys.path.append(notepad.getPluginConfigDir() + r'\PythonScript\lib')
                    It is a workaround until a fixed version is released.
                    Michael VincentM 1 Reply Last reply Reply Quote 5
                      Michael Vincent @mpheath
                      @mpheath said in Little Dialog-wrapper for PythonScript:
                      Afraid it’s not that easy for me. I’ve added all my missing directories to make it “on par” with the previous version, but I still get a ImportError that I do not get in the previous version:
                      ImportError: DLL load failed while importing win32gui: The specified module could not be found.
                      Rest assured, the module is installed correctly. I can import it from my system Python and from PythonScript 3.0.17 commit right before the commit that breaks the path that I note in my issue. I’ve tried adding the specific directories to both sys.path and os.environ["PATH"] as described in https://github.com/mhammond/pywin32/issues/1730 and other Google results.
                      Cheers.
                        Michael Vincent @Michael Vincent
                        @mpheath points out it is indeed “that easy” if you know what you are doing and thank you @mpheath for showing me what to do:
                        https://github.com/bruderstein/PythonScript/issues/322#issuecomment-2041020162
                        And my specific fix:
                        https://github.com/bruderstein/PythonScript/issues/322#issuecomment-2045932479
                        Cheers.
                        Michael VincentM 1 Reply Last reply Reply Quote 3
                          Not needed anymore - 3.0.18 is released which fixes this bug.
                          Cheers.
                            This is now fixed in the 3.0.18 release.
                            Cheers.
                            • Bruno BonaspettiB Offline
                              Bruno Bonaspetti
                              Hello, could someone show me how to download and install this translation plugin on notepad++, as I have a lot of things to translate and word translation doesn’t work as it should.
                                PeterJones @Bruno Bonaspetti
                                @Bruno-Bonaspetti ,
                                Have a little patience. You already asked that question yesterday here. This is not paid support that is guaranteed to get a reply in 5 minutes or your money back; this is a Community of fellow users of Notepad++, and as such, any who read here regularly and answer questions do so solely on their free time, and they might not always have time to answer a specific question – especially one that might take more knowledge of a specific sub-tool of Notepad++.
                                Furthermore, this topic, “Little Dialog-wrapper for PythonScript” is focused on the Dialog Wrapper library for the PythonScript plugin; it briefly mentioned a script that was using that wrapper to help with the user interface, but the translation is not the focus of this discussion.
                                Your original question was in the right place. This question was not. I will try to give a brief answer in the other topic.
