    Is it possible to keep a block folded when cutting and pasting?
    6 Posts 4 Posters 1.1k Views 2 Watching
    • pbarneyP Offline
      pbarney
      I’m dealing with a large HTML file that has many divs that need to be resorted by hand. It’s made much easier by folding the entire file to the appropriate level (in my case, by using alt-5), but when I cut a folded block and then paste it into it’s new location, it pastes unfolded.
      I don’t think this is possible in N++, given that line bookmarks also don’t copy and paste, but I thought I’d ask here first.
      PeterJonesP rdipardoR 2 Replies Last reply Reply Quote 0
        PeterJones @pbarney
        @pbarney said in Is it possible to keep a block folded when cutting and pasting?:
        Yeah, you are right: it’s not currently possible. To keep that kind of metadata through cut/paste actions would add a new layer or two of complexity (including the hijacking of messages that are currently passed directly to the underlying library that handles the cut/copy/paste… shudder) – and I’m thus doubtful that a feature request for that would be successful.
        You could record a macro that includes PASTE then UP-ARROW (to move back into the block from your paste, since a folded-paste will end with a newline puting your caret outside the block) then FOLD CURRENT LEVEL, and save it to a keystroke (like Ctrl+Shift+V for “modified paste”, or whatever shortcut you’d like) – then just train yourself to Ctrl+Shift+V for paste-then-fold
        pbarneyP 1 Reply Last reply Reply Quote 3
        • rdipardoR Offline
          rdipardo @pbarney
          @pbarney
          There’s a plugin that might be useful in this case:
          • pbarneyP Offline
            pbarney @rdipardo
            @rdipardo thank you! I currently use that plugin, specifically for the CTRL+T functionality (grateful for that!), but how might it help me with the folding/unfolding issue?
            By the way, your image hosting provider apparently pulled the image you pasted.
            • pbarneyP Offline
              pbarney @PeterJones
              @PeterJones said in Is it possible to keep a block folded when cutting and pasting?:
              Excellent idea! I’ll do just that. Thank you.
              • apk shelfA Offline
                apk shelf
