    Help - Update Notepad++ issue
    6 Posts 5 Posters 3.8k Views 4 Watching
    • datatraveller1D Offline
      datatraveller1
      If I call Help - Update Notepad++, I get a message:
      Xml Exception
      It’s not a valid GUP xml.
      OK
      Is this a known issue?
      • richluxR Offline
        richlux
        Same problem here: Version 8.5.3 on 64-bit Windows
        Rich
        Snabel42S 1 Reply Last reply Reply Quote 0
        • Snabel42S Offline
          Snabel42 @richlux
          @richlux same here
          • Snabel42S Snabel42 referenced this topic on
          • phil-nyeP Offline
            phil-nye
            Just download the latest installer from the the main Notepad++ site – https://notepad-plus-plus.org/downloads/v8.5.3/
            Overwrite your local installation as usual. It worked for me.
            datatraveller1D 1 Reply Last reply Reply Quote 2
              datatraveller1 @phil-nye
              @phil-nye Thank you this worked.
                PeterJones @datatraveller1
                I have reported this in the Announcement topic where @Snabel42 had reported about the captcha affecting Notepad++ Update, as well as I just created issue #13685. We’ll see if Don can get his ISP to turn that off for those URLs.
