    A little help with a regex (find & replace) ?
    9 Posts 3 Posters 2.5k Views 2 Watching
    • pickonedevP Offline
      pickonedev
      Hi!
      I don’t know how to use this regex thing… but if someone is kind and know how to help me, I am very thankful.
      This is my document
      microwave:
        value: initial
        restore: true
      kitchen_water_boiler:
        value: initial
        restore: true
      bed_motor:
        value: initial
        restore: true
      home_away:
        value: initial
        restore: true
      bedroom_heater:
        value: initial
        restore: true
      And I want to find & replace lines which does not contain any space, as an example, I want from this:
      bedroom_heater:
        value: initial
        restore: true
      to this
      variable_bedroom_heater:
        value: initial
        restore: true
      Anyone can help me with this?
      Thank you in advance!
        Hello, @pickonedev and All,
        OK… but which areas should be replaced ? I mean, do you want to change :
        • Any line without any space character, with a same string for all ( like variable_bedroom_heater, from your example ) ?
        • Any line without any space character, with a string with some relation to the original name ( like variable_microwave:, variable_kitchen_water_boiler:, variable_bed_motor:, and so on… ) ?
        • Any line without any space character, with a string totally different from the original name ( like device_1: instead of microwave:, device_2: instead of kitchen_water_boiler: and so on… ) ?
        pickonedevP 1 Reply Last reply Reply Quote 0
          pickonedev @guy038
          @guy038
          Well… take a look at this
          home_away:
            value: initial
            restore: true
          bedroom_heater:
            value: initial
            restore: true
          I want them like this:
          variable_home_away:
            value: initial
            restore: true
            value: initial
            restore: true
          I want to add “variable_” to every line which does not start with a space or tab.
          Till now, I have tried with ^\S but it is not adding variable_, it is only replacing the first character, with variable_
          I don’t know regex, I only try things till I have a result, but this is far over me :))
            Ah… OK ! In that case, use the following regex S/R :
            • SEARCH ^[^ \r\n]+$
            • REPLACE variable_$0
            • Tick the Wrap around option
            • Select the Regular espression search mode
            This regex S/R mean :
            • Seacrh for any complete line, between its beginning ( ^ ) and its end ( $ ) with, at least, one character different from a space char and different from any EOL chars ( \r and \n )
            • And replace each of these lines with the string variable_, followed with the entire regex search, i.e. $0
            BR
            pickonedevP 2 Replies Last reply Reply Quote 4
              pickonedev @guy038
              @guy038 Thank you so much.
              Now, I have an idea :-D Just for the fun
              If I have this:
              # Devices Status #
              loading:
                value: loading
                restore: true
              bathroom_boiler:
                value: initial
                restore: true
              and I want to change it to this
              # Devices Status #
              variable_loading:
                value: loading
                restore: true
              variable_bathroom_boiler:
                value: initial
                restore: true
              To add “variable_” as I first requested, but if a line starts with # to exclude it
              pickonedevP 1 Reply Last reply Reply Quote 1
                pickonedev @pickonedev
                @pickonedev
                I done it by myself, having your sample already :-D
                With ^[^ #\r\n]+$
                Thank youuuuuuu
                  PeterJones @pickonedev
                  @pickonedev said in A little help with a regex (find & replace) ?:
                  Useful References
                    pickonedev @guy038
                    @guy038
                    If I don’t ask too much, can you please help me one more time?
                    I tried to find and learn by myself but it is far far far over me, this regex… I don’t get it…
                    Here is a part from the document I have
                    service: switch.turn_off
                      data: {}
                      entity_id: switch.sonoff_computer_1
                      data: {}
                      entity_id: sonoff_computer_2
                    I want to add “sensor.variable_” to the lines which starts with "entity_id: " (even if there are spaces in front of it) but not contain the dot character " . "
                    For example, the document above, should look like this after the change:
                      data: {}
                      data: {}
                      entity_id: **sensor.variable_**sonoff_computer_2
                      When you set out to learn the piano, you should start with “Row, Row, Row Your Boat” and “London Bridge”, and work your way up through Canon in D to Chopin and Liszt, over years of practice.
                      The lesson: If you try to start with the more complicated, you will only end up discouraging yourself. Sometimes, with regex, it’s better to get a portion of it working, and then do the rest manually (so maybe try to search for something more generic that you can find, then use your own eyes to do the rest. Then, after more experimentation, you can figure out how to do more and more, until you can come up with pretty powerful regex.
                      Okay, this isn’t a full concerto, but it is an intermediate etude.
                      Break it into smaller chunks for developing:
                      1. line starts with entity_id: even if there are spaces => ^(\h*entity_id:)
                        • ^ = line starts with
                        • \h* = 0 or more spaces
                        • entity_id: = literal text
                        • (...) = we want to save this chunk for later; it will be group#1 and referenced later as $1
                      2. but the rest of the line does not contain the dot character => ([^.\r\n]+)$
                        • (...) = save the rest of the line as group#2 (later called $2)
                        • [^...] = make a “negative” character class, to define a list of characters that you don’t want to match
                        • [^.\r\n] = don’t want to match a literal period, or the CR or LF newline characters
                        • + = match 1 or more of the thing that came before – so in this case, “match 1 or more characters that are not period or newline characters”
                        • $ = match the end of the line
                        • thus, the only thing allowed for this portion of the search are characters that are not period or newline, and that extends all the way to the end of the line. It will thus match if the line doesn’t have a dot, and won’t match if it does.
                      3. Put it together: you want the first group, followed by a space, followed by the second group: ^(\h*entity_id:) ([^.\r\n]+)$
                      4. Replacement: you want to replace it with the first group, then a space, then the new text, then the second group: $1 sensor.variable_$2
                      Useful References
                      Please note: This Community Forum is not a data transformation service; you should not expect to be able to always say “I have data like X and want it to look like Y” and have us do all the work for you. If you are new to the Forum, and new to regular expressions, we will often give help on the first one or two data-transformation questions, especially if they are well-asked and you show a willingness to learn; and we will point you to the documentation where you can learn how to do the data transformations for yourself in the future. But if you repeatedly ask us to do your work for you, you will find that the patience of usually-helpful Community members wears thin. The best way to learn regular expressions is by experimenting with them yourself, and getting a feel for how they work; having us spoon-feed you the answers without you putting in the effort doesn’t help you in the long term and is uninteresting and annoying for us.
