    Is there a way to better distinguish between parentheses and braces?
    5 Posts 4 Posters 1.5k Views 2 Watching
    • 1 Offline
      1der1
      Most programming languages use a lot of parentheses and curly braces.
      Unfortunately, these look similar, mainly if you use a small font.
      Is there a way to make them more different?
      One way would be to allow different Notepad++ styles (including highlighting colour) for each type.
      Thank you for considering,
        Alan Kilborn @1der1
        @1der1
        I have never had trouble distinguishing parentheses and curly braces.
        Just how small of a font (and which font) are we talking about here?
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1der1 @Alan Kilborn
          @Alan-Kilborn, my screen resolution is 3840 x 2160. That means a lot of screen space, but the fonts look small.
            Ekopalypse @1der1
            @1der1
            Most, if not all, programming languages unfortunately use the same styles for the different brackets.
            There is a plugin called EnhanceAnyLexer, of which I am the developer, that allows you to change the color afterwards using regular expressions. I am working on how to change individual styles as well, but unfortunately there are some obstacles that I have not yet been able to overcome. At least not without introducing noticeably worse performance.
            • NicholasN Offline
              Nicholas
              Monoid is a customisable open source font designed for writing code in. https://larsenwork.com/monoid/
              There are other fonts out there as well if you search the web.
