    RegEx help
    2 Posts 2 Posters 766 Views 1 Watching
    • brenda grossB Offline
      brenda gross
      Want a RegEx to add – (two dashes, a comment in SQL) at the beginning of the line if a certain character or word is found in the line. Lines are terminated by \r\n.
      I have a bunch of DB2 SQL that i need to run on MS SQL. If certain non-SQL reserved words or characters are found for now i just want to comment out the statement
      input 3 sql statements. one has the character | and one has the work CONCAT
      SELECT '9' AS PTR, 'RATE POINTER 9 - ' CONCAT '0.0%' AS DESC FROM AABRAT WHERE AZFAO9 = 0
      SELECT '1', '$'|| REPLACE(LTRIM(EN_COMMARIGHT(INTEGER(DZOL01))),'.00','')  FROM     DDABCR
      SELECT '9' AS PTR FROM AABRST
      desired output after two REPLACE. Once for character | and one for work CONCAT. – is added at beginning of line
      --SELECT '9' AS PTR, 'RATE POINTER 9 - ' CONCAT '0.0%' AS DESC FROM AABRAT WHERE AZFAO9 = 0
      --SELECT '1', '$'|| REPLACE(LTRIM(EN_COMMARIGHT(INTEGER(DZOL01))),'.00','')  FROM     DDABCR
        Terry R @brenda gross
        @brenda-gross said in RegEx help:
        You could try this using the Replace function:
        Find What:(?-is)^(?=.*(?:CONCAT|\|))(.*)
        Replace With:--\1
        Search mode must be regular expression. You can click on “Replace” to do it singularly, or “Replace All” to change the entire open file.
        I do wonder though that the single character | might be used elsewhere. Hence why I say using the single Replace button so you step through the file and can check each line is correct for change before changing it.
