    Feature Request / Question: Soft Wrap at Vertical Edge (Column 80) regardless of window size
    22 Posts 8 Posters 6.2k Views 3 Watching
      Hello, @coises and All,
      I’ve just tried you last Marginalize plugin and the results are awesome !
      It’s particularly the case when using the Center the workspace option, in Plugins > Marginalize > Settings, which mimics the Distraction Free Mode, while retaining the standard screen !
      I’m sure that this plugin will become a MUST very soon for any N++ user !
      Many thanks, again, for this valuable plugin !
        Coises @fml2
        @fml2 said in Feature Request / Question: Soft Wrap at Vertical Edge (Column 80) regardless of window size:
        @Coises Thank you for the quick implementation! If enebaled, it applies to all documets, not just the current one, right?
        Yes, I made it a single toggle for all documents in both views.
        It would be possible, but considerably more complex, to track documents and enable/disable per document. (I do it with elastic tabstops in Columns++.)
