    Deleting in column mode doesn't work as expected
    3 Posts 2 Posters 4.3k Views 1 Watching
    • Albert BihlerA Offline
      Albert Bihler
      I am currently on 6.8.3. For me deleting in column mode doesn’t work as expected anymore. E.g. if I start column mode on 3 lines and start writing everytging looks ok (read pipe sign as cursor):
      test|
      test|
      test|
      backspace works well:
      tes|
      tes|
      tes|
      but if I try to delete something
      test|x
      test|x
      test|x
      it just deletes only in one LINE and kicks me out of column mode. The result looks like this:
      testx
      testx
      test|
      I am 100% sure this used to work. Any ideas what I am doing wrong?
      Best regards,
      Albert
      • dailD Offline
        dail
        I tried with v6.8.3 and it seems to work fine. Try disabling your plugins, you can just rename your plugins folder to something else temporarily.
          Albert Bihler
          thank you for the hint. It turned out that visimulator.dll in my plugins folder messed things up. Without that plugin column mode works again as expected.
          Regards,
          Albert
