    Problem with Launch In Firefox (with x64 Firefox)
    bug with ff64
    2 Posts 1 Posters 5.1k Views 1 Watching
    • Franco PetitF Offline
      Franco Petit
      Hello everyone.
      Firefox has a x64 version now.
      But “Launch In Firefox” doesn’t work.
      Screen : http://i.imgur.com/SVV6iNr.png
      I’ve open this file : %programfiles(x86)%\Notepad++\shortcuts.xml
      I’ve wanted modify this line :
      • <Command name=“Launch in Firefox” Ctrl=“yes” Alt=“yes” Shift=“yes” Key=“88”>firefox “$(FULL_CURRENT_PATH)”</Command>
      Because I think this line use firefox x86 path.
      And the firefox x64 path is : %programfiles%\mozilla firefox\firefox.exe
      How modify the line with this path ?
      I’ve re-installed notepad++ but same problem.
      Thanks ;)
      Sorry for mistakes, I’m french.
      Best Regards.
        Franco Petit
        Hi.
        Problem Solved.
        Found here : https://unacatarsisdetransfiguracion.wordpress.com/2007/11/04/how-to-open-a-file-in-opera-from-notepad/
        Solution : I edit the Windows Registry to add firefox.exe (x64) in “app Paths” key.
        reg.exe add “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\firefox.exe” /ve /d “%programfiles%\mozilla firefox\firefox.exe” /f
        I think it was old path, firefox x86.
        Bye :)
