    how to copy paragraphs found using regular expression
    2 Posts 2 Posters 2.4k Views 1 Watching
    • Aman JainA Offline
      Aman Jain
      The bookmark line option in ‘mark’ only marks the first line of a paragraph but i want the entire paragraph should be marked
        Hi Aman Jain,
        I can’t figure out, exactly, what you’re trying to do :
        • Do you need to cut/copy these bookmarked lines ( Menu Search - Bookmark ) ?
        • Do you speak about wrapped lines, when the View - Word wrap option is set ?
        • How do you, personally, define a paragraph ?
        So, could you show us a short example of what you would like to ?
