    Problem with 6.8.8 after installing plugin
    2 Posts 2 Posters 3.7k Views 1 Watching
    • David SteinD Offline
      David Stein
      Possible bug in 6.8.8? Or maybe it’s the plugin. Anyhow, I’m on Windows 10, 1511 (10586.29), 64-bit with NP++ 6.8.8 installed. When I install the PowerShell Lexer plugin from the Plugin Manager, it prompts me to restart NP++. I click Yes and it closes. But it won’t restart. Not even when launching from the app shortcut. Watching task manager it doesn’t even appear to attempt to launch. If I delete the plugin DLL from the plugins folder, NP++ launches and runs just fine.
      • dailD Offline
        dail
        Definitely sounds like a problem with the plugin. I’d report it to the authors of the PowerShell Lexer plugin.
        Just as an FYI, Notepad++ does support PowerShell.
