    Unit Conversion Plugin
    18 Posts 3 Posters 17.7k Views
    • Jared HowardJ
      Jared Howard
      I am new to plugin development and wanted to ask if anyone has developed a metric to imperial or imperial to metric plugin for use with notepad++?
      I need to convert mass amounts of data and would like to be able to alt + shift select a group of values and activate the plugin to convert.
      If nobody has developed this, any tips or tricks is appreciated.
      Thanks
      • dailD
        dail
        None exist that I’m aware of. This sounds like a fairly straight forward plugin. Your best bet is to install the Python Script plugin and you can write your plugin in Python. It would probably end up being < 50 lines of code. You could also use C/C++ or C# or something but the work involved in that for what you are doing probably isn’t worth it.
        • Claudia FrankC
          Claudia Frank @Jared Howard
          Hello Jared-Howard,
          if you are looking for a python solution it might look like this
          editor.beginUndoAction()
          def conv_mile_kilometers(miles):
              km = int(miles) / 1.6
              return km
          for i in range(editor.getSelections()):
              start = editor.getSelectionNStart(i)
              end = editor.getSelectionNEnd(i)
              word = editor.getTextRange(start,end)
              editor.setTarget(start, end)
              editor.replaceTarget('{0}'.format(conv_mile_kilometers(word)))
          editor.endUndoAction()
          Just be aware that you select numbers only as I didn’t do any error checking.
          What needs to be done first is described here.
          • Jared HowardJ
            Jared Howard
            Thank you both, I will play around with it and see if I can get it to work.
            • Jared HowardJ
              Jared Howard
              I was able to get it to work, however is there a command so that the selection will include decimal values?
              For example when I run the script it will convert “25” but not “25.4”
              Thanks again
              • Claudia FrankC
                Claudia Frank
                just change
                to
                km = float(miles) / 1.6
                • Jared HowardJ
                  Jared Howard
                  Excellent, has been working nicely so thank you for the help!
                  One last thing, is there a way to get the script to work when selecting multiple values when they are separated by a comma?
                  Example
                  25.4, 50.8,
                  • Claudia FrankC
                    Claudia Frank
                    Yes, splitting a line is easy but depends on what is assumed as input.
                    Let’s say you have a line like
                    25.4, 50.8, ...
                    or lines like
                    25.4, 50.8, ...
                    27.4, 54.8, ...
                    or
                    25,4, 50,8, ...
                    from scripts point of view either one could break the logic, even in the way how you select the values.
                    So question is what is/are your preferred way(s)? Depending on that we should be able to find a solution.
                    • Jared HowardJ
                      Jared Howard
                      Lines are typically separated by a space, however can vary as to if they have a decimal point or not. They will most likely always be a variation of the below.
                      2.99, 10,
                      3.98, 9,
                      0.25, 0.39,
                      0.25, 0.39,
                      • Claudia FrankC
                        Claudia Frank
                        Can I safely assume that you always use ALT+SHIFT to select the values?
                        This is critical because selecting with ALT+SHIFT and arrow right etc. results (taking your example) in
                        Selection:0 Values:2.99, 10,
                        Selection:1 Values:3.98, 9,
                        Selection:2 Values:
                        Selection:3 Values:0.25, 0.39,
                        Selection:4 Values:0.25, 0.39,
                        whereas using CTRL+ALT would result in
                        3.98, 9,
                        0.25, 0.39,
                        0.25, 0.39,
                        As you see, the first would report 5 selections, each line as one selection where as
                        the second reports one selection for all 5 lines.
                        If using ALT+SHIFT we need to check if line has valid values (empty lines issue),
                        then split by comma, do conversion for each value and rebuild string.
                        Should we go this way?
                        • Jared HowardJ
                          Jared Howard
                          Correct, I always use ALT+SHIFT for selection. Your proposal sounds like the correct way to proceed.
                          Thank you again for your assistance. I am more versed in Pascal and am not very fluent yet with Python.
                          • Claudia FrankC
                            Claudia Frank
                            I did some tests(empty line, just a comma, double comma) and I guess this should do the trick
                                list_of_values = miles.split(',')
                                km = ''
                                for value in list_of_values:
                                    if len(value) > 0 and value.isspace != True:
                                        km += str(float(value) / 1.6) + ','
                                return km
                                if len(word) > 0 and word.isspace != True:
                            • Claudia FrankC
                              Claudia Frank
                              Correction:-(
                              Unfortunattely I cannot edit my post so
                              both isspace items need to be changed to isspace()
                              because they are functions.
                              Full code
                                  km = ''
                                      if len(value) > 0 and value.isspace() != True:
                                  return km
                                  if len(word) > 0 and word.isspace() != True:
                              • Jared HowardJ
                                Jared Howard
                                Excellent it works great, thank you!
                                The last question I have regarding this is how do I format the number of decimals that the values get returned as when converted?
                                • Claudia FrankC
                                  Claudia Frank
                                  Hello Jared,
                                  I’m sorry I don’t understand your question could you gimme an example
                                  of what you want to do?
                                  Thanks
                                  • Jared HowardJ
                                    Jared Howard
                                    Sorry I see my wording was not clear.
                                    Once I convert say millimeters to inches is there a way to control the number of decimal places?
                                    1.33 inches converted to metric is = 33.782
                                    I want the value to only display 2 decimal places, 33.78. How is that accomplished?
                                    Thanks again!
                                    • Claudia FrankC
                                      Claudia Frank
                                      this can be done using format’s strength.
                                      Within the try block we need to change the following line
                                      to
                                      km += '{0:.2f},'.format(float(value) / 1.6)
                                      Short explanation, the placeholder {0} receives the result from the
                                      calculation float(value) / 1.6.
                                      By specifying the colon after the zero, the format function gets informed
                                      that the result needs to be reformatted.
                                      The dot after the colon defines precision formatting,
                                      the number 2 specifies only 2 decimal places and the letter f is to inform that it is
                                      a float which needs to be formatted.
                                      But we can go one step further, if you are interested in keep the number of
                                      decimal places of the input and the output value the same then
                                      we can replace the km += … line with the following two lines.
                                      decimal_places = str(value)[::-1].find('.')
                                      km += '{0:.{1}f},'.format((float(value) / 1.6),decimal_places)
                                      as you see, the 2 is now replaced with another placeholder{1} which
                                      get the value of decimal_places variable, which itself gets the value
                                      from a stringified value where we search for the dot from right to left (that is what the -1 stands for).
                                      • Jared HowardJ
                                        Jared Howard
                                        Outstanding!
