    Smart HighLighting for multiple view !
    9 Posts 2 Posters 8.5k Views 2 Watching
    • Marvin GerardinM Offline
      Marvin Gerardin
      I search a way to display all variables on all view.
      Ex: http://fr.tinypic.com/r/e13ln5/9
      Thank you for your help
        Claudia Frank @Marvin Gerardin
        Hello Marvin Gerardin
        I have a python script which could almost do what you want.
        What needs to be done first is described here.
        def clearScintillaCallbacks():
            editor.clearCallbacks([SCINTILLANOTIFICATION.DOUBLECLICK, SCINTILLANOTIFICATION.INDICATORCLICK])
        def clearIndicators():
            text_end_position1 = editor1.getLength()
            text_end_position2 = editor2.getLength()
            editor1.setIndicatorCurrent(8)
            editor1.indicatorClearRange(0, text_end_position1)
            editor2.setIndicatorCurrent(8)
            editor2.indicatorClearRange(0, text_end_position2)
        def toggleview():
            # 0 = main_view
            # 1 = second_view
            current_doc_index_main_view = notepad.getCurrentDocIndex(0)
            current_doc_index_second_view = notepad.getCurrentDocIndex(1)
            if notepad.getCurrentView() == 0:
                notepad.activateIndex(1, current_doc_index_second_view)
            else:
                notepad.activateIndex(0, current_doc_index_main_view)
        def colorize():
            selected_text = editor.getSelText()
            clearIndicators()
            toggleview()
            matches = []
            editor.research('\\b{0}\\b'.format(selected_text), lambda m: matches.append(m.span(0)))
            for match in matches:
                editor.indicSetStyle(8,INDICATORSTYLE.ROUNDBOX)
                editor.indicSetFore(8,(117,217,117))
                editor.indicSetAlpha(8,255)
                editor.indicSetOutlineAlpha(8,255)
                editor.indicSetUnder(8,True)
                editor.setIndicatorCurrent(8)
                editor.indicatorFillRange(match[0], match[1] - match[0])
            toggleview()
        def sci_callback_DOUBLECLICK(args):
            if editor2:
                colorize()
            else:
        def sci_callback_INDICATORCLICK(args):
            clearIndicators()
        editor.callback(sci_callback_DOUBLECLICK, [SCINTILLANOTIFICATION.DOUBLECLICK])
        editor.callback(sci_callback_INDICATORCLICK, [SCINTILLANOTIFICATION.INDICATORCLICK])
        I hope that code itself is self-explaining mostly therefore I only describe
        the critical parts and how it should be used.
        The script itself registers two callback functions,
        sci_callback_DOUBLECLICK and sci_callback_INDICATORCLICK.
        When you doubleclick on a text the function gets called
        and tries to find the selected word in the 2nd view. If it
        can be found it marks it. If you click (only one mouse click)
        on the marked text, highlighting disappears.
        If you click anywhere else only the highlighted text in this view
        loses its markings. If you close the second view and double click
        on a text then all callbacks will be cleared.
        So, after you created the script
        run it
        open both views and
        play with it by double clicking words.
        As already described, 2nd view needs to be active before
        you double click words or callbacks get cleared and you
        need to run the script again.
        One minor issue I discovered while testing.
        It happened to me that words which were already
        highlighted got cleaned again. Not sure why?
        But it looks like this only happens if you
        often double click in short time.
        If this is all greek to you let me know I try to clarify.
          Marvin Gerardin
          Thank you for your reply.
          This work with 2 identical file (WinMerge)
          http://i66.tinypic.com/xqgm85.png
          what I would like:
          http://i68.tinypic.com/2mma5nr.png
            Hello Marvin-Gerardin
            at the beginning of your script put
            import re
            which means import the regular expression module.
            and change the line
            with
            editor.research('{0}'.format(selected_text), lambda m: matches.append(m.span(0)),re.IGNORECASE)
            which forces the research function to, well, ignore the case. And missing of \\b has the additional feature to ignore
            whether this is a whole word or just part of a word.
              Marvin Gerardin
              @Claudia-Frank said:
              which forces the research function to, well, ignore the case. And missing of \b has the additional feature to ignore
              No work :/ http://i64.tinypic.com/169ruxg.png
              def toggleview():
              # 0 = main_view
              # 1 = second_view
              else:
              def colorize():
              clearIndicators()
              toggleview()
              matches = []
              toggleview()
              if editor2:
              colorize()
              else:
              clearIndicators()
                Claudia Frank
                I don’t see the
                import re
                line, which would break the whole script.
                Could you open console (Plugins->Pytrhon Script->Show Console)
                and run the script again. Do you get any errors?
                  Marvin Gerardin
                  is my script:
                  https://drive.google.com/file/d/0B884biTIbPZ-ekU3V2VqZGtKXzg/view?usp=sharing
                  in :
                  C:\Users*\AppData\Roaming\Notepad++\plugins\Config\PythonScript\scripts
                  I do not understand what I have to do in the console :/
                  I have a message:
                  PluginsManager::runPluginCommand Exception
                  Unknown exeception
                  and this : http://i64.tinypic.com/4r2hqe.png
                    @Marvin-Gerardin
                    sorry have to leave - will come back on this next year ;-)
                      Claudia Frank
                      So let’s summarize.
                      The script worked before but not as expected
                      because the original version matched only whole words
                      and not if the searched word is part of another word.
                      To change this I changed
                      to
                      editor.research('{0}'.format(selected_text), lambda m: matches.append(m.span(0)))
                      then I thought maybe there can be also a difference in notation
                      therefore I included regex module
                      import re
                      and added the ignorecase flag to the research function.
                      Which broke not only your uploaded code, which by the way is working for me,
                      but also the python script plugin??
                      This is weird. There is nothing fancy here. re module is part of the standard python lib.
                      OK, please comment the import re line
                      # import re
                      and change the editor.research … to
                      and do another test.
                      You do not need to do anything in the python script console, just open it, it serves as an
                      error output window if something within the python code is wrong.
                      For example if you add the re.IGNORECASE flag but you do not import re module first
                      the error would be shown in the console window as soon as you double click on a word.
                        File "...\Notepad++\plugins\Config\PythonScript\scripts\Highlight.py", line 42, in sci_callback_DOUBLECLICK
                          colorize()
                        File "...\Notepad++\plugins\Config\PythonScript\scripts\Highlight.py", line 29, in colorize
                      NameError: global name 're' is not defined
                      May I ask you which OS, npp and python script plugin version you use?
