    What standard for Regular Expressions is Notepad++ using?
    5 Posts 3 Posters 8.5k Views 1 Watching
    • Tony De GrootT Offline
      Tony De Groot
      I have been using Notepad++ for occasional general editing for a couple of years, and find it very useful.
      I am starting to explore regular expressions but I have no reference for the regular expression terms or syntax. Can someone point me at a reference for the regular expressions used in Notepad++?
      My baseline for Regular Expressions is on Edit/1000 under RTE/A for HP Minicomputers (1985) and early HPUX, but nothing for the last 20 ish years as I only dabble in Unix/Linux … I saw the syntax change quickly in the early days but do not know if it has stabilised into a common format by now …
      Thanks,
      Tony.
        Scott Sumner
        You will find an exhaustive discussion of the Notepad++ regular expression “flavor” here:
        https://notepad-plus-plus.org/community/topic/9703/is-it-planned-to-switch-to-pcre2
        Perhaps that contains a deeper treatment than you want/need. Basically N++ currently uses the BOOST implementation, and these TWO links, which are buried in the above link, are very helpful in understanding Notepad++'s regexes:
        SEARCHING:
        http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/syntax/perl_syntax.html
        REPLACING:
        http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
          Tony De Groot
          Hi Scott,
          Thanks for the help.
          I have all my editting done except for deleting lines.
          From the command line I would use something like:
          1$f/^“”/,d
          to search the file, find all occurrences of 2 quotes at the start of a line, and then delete that line. Repeat until end of file.
          I cannot see if there is a facility to drop into a command line, nor can I find a delete option in the Search/Replace menu.
          Can you tell me what I am missing?
          Thanks,
          Tony
            Hello Tony,
            You can get this action, by two means, with Notepad++ :
            • by performing a simple Search and Replace operation, in regular expression mode
            • by deleting all the bookmarked lines, which contain two double quotes, at the beginning of each line
            First method :
            • Open the Replace dialog ( CTRL + H )
            • SEARCH ^"".*\R
            • REPLACE Nothing
            • Check the Wrap around option
            • Check the Regular expression search mode ( Important )
            • UNCHECK the .matches newline option, if necessary
            Notes :
            • ^ is an assertion, that represents the location between the last EOL character of the previous line and the first character of the current line
            • .* then matches the rest of the line, after the two double quotes
            • \R stands for any kind of EOL characters ( \r\n, for Windows files, \n, for Unix files or \r for old Mac files )
            • As the replacement zone is empty, then, the entire lines, containing "", at beginning of lines are deleted
            Second method :
            • Open the Mark dialog ( Menu Search - Mark… )
            • SEARCH ^""
            • Check the Bookmark line option
            • Select the menu option Search - Bookmark - Cut Bookmark Lines
              Tony De Groot
              Hi guy038,
              I had used part of your first example - I used search for ^“”, but missed the rest of the line. Using the complete expression worked fine.
              Many thanks,
              Tony
