Miss position after switch between tabs
Hi
I have a problem with switching between tabs.
If you switch between any tabs, cursor jump to ** 1:1** position!
User miss the last position and programmer says hello!
Hello Alireza-Abedini,
checked on Win7 x64 npp 6.8.8.
4 tabs open
tab1 -> cursor position line 100
tab2 -> cursor position line 2
tab3 -> cursor position line 12
tab4 -> cursor position line 250rapidly switched the documents by clicking the tabs multiple times. ~ 50 times
Cursor is still in the position where it was.Cheers
There is a known issue with the XML Tools plugin. There is a certain option you can turn off but I can’t remember which one. I’d suggest updating the plugin.
Hello, Alireza Abedini and dail,
Indeed, this problem occurs, when the XML Tools plugin is installed, in your N++ configuration. Just refer to this old dail’s post :
https://notepad-plus-plus.org/community/topic/33/return-to-same-line-when-switching-tabs/3
Best Regards
A BIG thanks for you and a I wish for you to upgrade to 39 as soon as possible ;)Best Regards,
Alireza
