    • Categories
    • Recent
    • Tags
    • Popular
    • Users
    Beginner - Help w/multiple record edits
    Help wanted · · · – – – · · ·
    2.3k
    • Bill CampbellB
      Bill Campbell
      I’ve got a CSV-formatted UAV telemetry file with 2700 records. The first record is the header. For some reason the first field, the datetime field, is not labeled in the header. So I need to add the word “Time” to the header:
      ,fsk_rssi,voltage,current,altitude,latitude,longitude,tas,gps_used,fix_type,satellites_num,
      to:
      Time,fsk_rssi,voltage,current,altitude,latitude,longitude,tas,gps_used,fix_type,satellites_num,
      Next, the beginning of each record is a timestamp, as follows:
      20151227 11:34:03:070,
      but my visualizer program requires the format to be:
      2015-12-27 11:34:03.070,
      adding a dash between year and month; adding a dash between month and day; and changing the last colon (:) to a period (.).
      I’ve manually made these changes using column mode but figure there must be an easier way. Any ideas? Thanks!
      Bill
      • Claudia FrankC
        Claudia Frank @Bill Campbell
        Hello Bill-Campbell,
        if the data is always in the same layout you could record a macro and save it with a meaningful name.
        After it has been saved it appears in the Macro menu.
        What needs to be done, after having the document with the needed data loaded, is
        • press record macro
        • press strg+home (this is to make sure that cursor is on the first line on first position)
        • tpye time,
        • press strg+h (replace dialog opens, check regular expression and put in the following)
        • Find what: (\d{4})(\d{2})(\d{2})(\s\d{2}:\d{2}:\d{2})(:)(.*)
        • Replace with: \1-\2-\3\4.\6
        • press alt+a
        • stop recording and save it.
        Requirements, the layout must be always
        year 4 digits = (\d{4})
        month 2 digits = (\d{2})
        day 2 digits = (\d{2}) and
        (\s\d{2}:\d{2}:\d{2})(:)(.*) is
        a whitespace char \2 followed by
        hour 2 digits + colon + minute 2 digits + colon + seconds 2 digits + colon + the rest.
        If the layout hasn’t always this structure, eg month january is reported as 1 instead of 01,
        than I guess a python script, which means installation of python script plugin, is needed or
        someone else has more sophisticated idea of using regex.
        • Bill CampbellB
          Bill Campbell
          Claudia,
          My data is always in the same format, so a macro would work. Thank you very much for the coding!
          Bill Campbell
