    Need some Help with Filtering out my Text
    3 Posts 2 Posters 2.4k Views 2 Watching
    • Aaron MillerA Offline
      Aaron Miller
      I have a screenshot here: http://prntscr.com/9sqct4
      I want to remove everything that comes before “|” as well as the “|” itself. Or keep everything that has http:// and after.
      I’m very new to notepad ++ and would love some help on this issue! Thank you :)
        Claudia Frank @Aaron Miller
        Hello Aaron-Miller
        open replace dialog and put the following into find what:
        (.+|)(?=http.*)
        leave replace with empty.
        Select Regular expression in Search mode and press replace all.
        Keep a copy of the original data for safety ;-)
        What it does is
        .* look for every char until a | appears and if http follows, then make it a group
        to be reported back (known as match).
        As replace with hasn’t anything in it this group will be replacey with nothing.
        Hope this makes sense.
        Btw. I assume that | appears only once and directly before http
          Aaron Miller
          I do understand. It worked. Thank you so much Claudia!
