    comma delimited columns that has been done wrongly and I need to rearrange
    8 Posts 3 Posters 4.9k Views 2 Watching
    • Camilo de BarrosC Offline
      Camilo de Barros
      Hi
      I have a long file with comma delimited columns that has been done wrongly and I need to rearrange it, preferably by getting all the columns tabulated, i.e. starting at the same distance from the left edge, so that I can then cut and paste a column from one place to another
      Here is an example:
      HI.jpg,HolidayInn,USA,IN,Portland,n,n,y
      HI.jpg,HolidayInn,USA,IN,Indianapolis,n,n,y
      HI.jpg,HolidayInn,USA,IN,Greensburg,n,n,y
      I need to eliminate the State (IN) and place it as part of the City with just a space:
      HI.jpg,HolidayInn,USA,Portland IN,n,n,y
      Ideally, can I do this to start?
      HI.jpg,HolidayInn,USA,IN,Portland ,n,n,y
      HI.jpg,HolidayInn,USA,IN,Indianapolis ,n,n,y
      HI.jpg,HolidayInn,USA,IN,Greensburg ,n,n,y
      So that I can then cut the IN column and paste it in front of the City?
      Thanks
        Claudia Frank @Camilo de Barros
        Hello Camilo-de-Barros,
        with the given example a regex can do this.
        Open replace dialog, select regular expression and put the following into
        find what   : ^(.+?),(.+?),(.+?),(.+?),(.+?),(.+)$
        replace with: \1,\2,\3,\5 \4,\6
        What it does is:
        ^ = start of line
        (.+?), = looking for one or multiple chars followed by a comma consuming as less chars as possible
        (.+)$ = take the rest until end of line(eol)
        each \X represents its corresponding match of (.+?) or (.+)
          Camilo de Barros
          Hi Claudia
          A small problem. The code below eliminates field 4 (Great!) but its contents (the 2 letter city code) must be inside field 5 (at the end with a space before it). Then the next 3 fields stay as they are: 7 fields in all.
          \1,\2,\3,\5 \4,\6
          Sorry…
            Hello Camilo,
            did you try it?
            I did not eliminate match 4 I rearranged it \5 \4
            \1, = first match and comma
            \2, = second match and comma
            \3, = third match and comma
            \5 \4, fifth match and space and fourth match and comma
            \6 = rest until eol
              Camilo de Barros
              Hi Claudia
              I should have tried it first. It’s working!
              One little problem though…
              Before I got your answer I downloaded XML Tools Plugin and played around with it. Now, the text has gone very small and I cannot change it in Style Configurator. I suppose I can always uninstall and reinstall Notepad++ but do you know what might be happening?
              Thanks
              Camilo
                Hi Camilo,
                I assume you activate zooming accidentally by pressing CTRL and using the mouse wheel. Could this be?
                If so, VIEW->ZOOM->Restore default zoom might undo it.
                  Camilo de Barros
                  Perfect!!!
                  You’re an angel!
                  Many thanks
                  Camilo
                    Hello Camilo,
                    In addition to the Claudia’s Search/Replacement, we could simplify and shorten a bit this S/R, as below :
                    Find what:       ^(?:.+?,){3}\K(.+?,)(.+?),
                    Replace with :   \2 \1
                    Notes :
                    • ^ represents the classical assertion Start of line
                    • (?:.+?,){3} represents a non-capturing group, repeated three times, exactly, in order to go through the first three columns. This group is the smallest range of standard characters, with its comma delimiter
                    • The \K syntax forces the regex engine to forget any previous match of the regex
                    • So, the remainder, (.+?,)(.+?),, is the final match, which gets the 4th column along with the comma delimiter AND the 5th column, without its comma delimiter
                    • In replacement, the syntax \2 \1 just swaps these two columns, with a space between them
                    IMPORTANT :
                    As the \K form is used, your MUST perform a global replacement, clicking on the Replace All button.
                    The Step by Step replacement, with the Replace button, does nothing, in that specific case ( N++ bug ) !
                    Best regards,
