    Need help defining UDL.
    3 Posts 2 Posters 4.0k Views 2 Watching
    • Ebm DendermondeE Offline
      Ebm Dendermonde
      Hi all,
      I’d like some help defining a “User Defined Language”. The programming language I’d like to add is Beckhoff Structured Text.
      Preview of the code
      In our code bVwn [0,1] := resembles the transit from “step 0” to “step 1”.
      What I’d like to do is color the brackets and comma in blue and the numbers in a more gold-like color (as done in the visual studio environment).
      Most of the other coloring and keywords are defined. I’ve already defined the brackets as “Operators 1”.
      Screenshot
      The number recognition is set to the settings in this picture.
      Many thanks in advance!
      KR,
      Bart
        Claudia Frank @Ebm Dendermonde
        Hello @Ebm-Dendermonde,
        define [] as delimiters and allow nesting numbers and operator 1 and define comma as operator 1 with the same colour as delimiter.
        Or I misunderstood your question and you maybe need to clarify.
        Ebm DendermondeE 1 Reply Last reply Reply Quote 1
          Ebm Dendermonde @Claudia Frank
          @Claudia-Frank That did it! Thanks!!!
