Navigation
    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Comment-like keywords ?
    Help wanted · · · – – – · · ·
    • Renaud Sirdey
      Renaud Sirdey last edited by
      Hi community,
      I am currently writing a style for a new programming language (that one is for kids, and it’s in French, so it’s for French kids ;-).
      I’d like to have a specific keyword for a print instruction which would more or less work as a comment :
      e.g. writing
      print whathever is written after the print keyword is not considered a keyword w. r. t. syntax highlighting
      I tried a number of things: comments (but I do have proper comments so reuse is bad, furthermore accentuated letters appear not to be supported in comment openings), keywords in prefix mode (but I could not completly understand what these are) and a few others…
      Many thanks in advance for any help with this,
      Best regs,
      Claudia Frank 1 Reply Last reply Reply Quote 0
      • Claudia Frank
        Claudia Frank @Renaud Sirdey last edited by
        @Renaud-Sirdey
        I assume you are using UDL and define a new language. If this is the case,
        then I would propose to use a delimiter definition instead of keyword and
        use the special command ((EOL)) as closing word. E.g.
        when having text like
        some text
        additional text
        print statement
        some further text
        and another print statement
        and using word print as the opening delimiter and ((EOL)) for closing
        the lines with print would get coloured.
        Is it this what you try to achieve?
        • Renaud Sirdey
          Thanks a lot Claudia,
          It’s close to it.
          Here is exactly what I am trying to achieve with UDL :
          Assuming for example that ajouter, à and dans are keywords of my langage and écrire (also a keyword) is my print instruction.
          Then I’d like the input line
          ajouter 1 à x dans x
          to show as
          whereas I’d like the input line (which will print the message “ajouter 1 à x dans x”)
          écrire ajouter 1 à x dans x
          to show as
          The solution you propose almost does it (it does indeed not highlight the keywords after écrire however all the words on the line are bound to the same style).
          Also, there seems to be an issue when accentuated letters are used as delimiters (i.e. it works with ecrire but not with écrire).
          Since I am developping a French language, this latter issue is important to me.
          Anyhow, many thanks for your first reply and many thanks in advance for any further insights you may provide,
          B. r., Renaud
          • Claudia Frank
            Hello Renaud,
            seems you are right, you can use it as keywords but not as comment or delimiters and
            the second question about having the print statement colored and the following text not
            even if keywords are located is, afaik, also not possible, sorry.
            I guess this is the best you can have at the moment.
            • Renaud Sirdey
              Ok thanks a lot Claudia,
              I will follow up on this post when I settle on some solution.
              Renaud
