    How to activate function lists in Notepad++
    function list
    5 Posts 2 Posters 14.2k Views 1 Watching
    • Kurt LudikovskyK Offline
      Kurt Ludikovsky
      The question might sound stupid.
      I am using NP++ 6.8.8 (the latest I addording the homepage)
      I would like to use the function list (basically as described here), with nothing special, just to see PHP-functions.
      I can open the function list window, but don’t see any functions.
      Do I need to do something to get this working?
      The functionList.XML - in the NPP installation directory - looks OK.
      I have not used function lists until now, but know it worked some time back.
      • dailD Offline
        dail
        Check to see if there is a functionList.xml file in your %APPDATA% directory. If it looks like that one is missing support for PHP then just delete it.
          Kurt Ludikovsky
          FunctionList.xml ist there - as I wrote above - and looks ok (??). At least if I look at it like in the linked document reference.
          • dailD Offline
            dail
            Assuming you did the default install there will be two versions of functionList.xml. One in the same directory as notepad++.exe and one in the appdata directory.
              Kurt Ludikovsky
              @dail: Thanks that solved it.
              This in the %APPDATA% has only 3 Languages in there, while the one in the Programm-Directory has many languages defined.
              So deleting (acutally renaming) the file in the %APPDATA% made the other definition-file work.
              Then there WAS just anothe slight issue, that the functions in PHP have not been recognised when the <?PHP ist not properly closed with the ?> (Reported here http://stackoverflow.com/questions/35101807/notepad-function-list-php-not-working-if-i-didnt-close-the-php-tag)
