Notepad++ / NppFTP does not work with USING PRIVATE KEY FILE
Notepad++ can not connect to the server which is using a ssh key file. ID with PASSWORD is working good, but USING PRIVATE KEY FILE does not work.
Error message is like below…
[SFTP] Host key accepted
[SFTP] Error during authentication: Access denied. Authentication that can continue: publickey
Unable to connect
DisconnectedBut, this key is working good with putty/filezila/editplus and so on.
Does anyone know a way to fix this?
It seems a kind of bug.I have updated the latest npp and NppFTP plugin alike. But there was no difference.
Thanks a lot. -
Hello @Jae-Hun-Daniel-Hwang,
I don’t have an environment to test it, so I was checking NppFTP
issues and there has been a similar issue reported with a possible solution
reported at stackoverflow.Cheers
