    Multi selection and multi edit
    multiline
    64 Posts 18 Posters 271.5k Views 8 Watching
    • bitagorasB Offline
      bitagoras @bitagoras
      I released a Notepad++ bundle where the multi selection is already installed, so you can simply test it:
      https://github.com/bitagoras/PyPadPlusPlus/releases
      It’s actually a portable version that includes a Python environment. But you don’t need this for mult selection.
      Below you can see how this looks like. The only non-standard edit command I used here is <Strg> + <D>.
      • Alan KilbornA Online
        Alan Kilborn @bitagoras
        @bitagoras said in Multi selection and multi edit:
        <Strg> + <D> ??
        What does that mean?
        bitagorasB 1 Reply Last reply Reply Quote 0
          bitagoras @Alan Kilborn
          Sorry, I use a German keyboard. I wanted to write <Ctrl> + <D> ;-)
            donho @Chandler Newby
            FYI: This feature is implemented in Notepad++ core and it’ll be available in the next release.
            You may want to check the PR to see if it meets your need:
            https://github.com/notepad-plus-plus/notepad-plus-plus/pull/14313
