    Syntax highlight block comment should override same for line comment
    2 Posts 2 Posters 2.6k Views 2 Watching
    • Cees TimmermanC Offline
      Cees Timmerman
      CoffeeScript uses ### ... ### for block comments, which works fine, but when i add a # ... line comment style to my UDL it breaks the block comment highlighting. Somehow the built-in CoffeeScript syntax highlighter does properly order the comments.
      Notepad++ v6.9
      Build time : Feb 21 2016 - 21:27:55
      Admin mode : ON
      OS : Windows 10
      Plugins : ComparePlugin.dll Explorer.dll HTMLTag_unicode.dll JSMinNPP.dll mimeTools.dll NppCCompletionPlugin.dll NppConverter.dll NppExec.dll NppExport.dll NppFTP.dll NppMenuSearch.dll NppTaskList.dll PluginManager.dll Python Indent.dll ScrollPastEOFUni.dll SpeechPlugin.dll sql.dll Tidy2.dll XMLTools.dll XPatherizerNPP.dll
        Claudia Frank @Cees Timmerman
        Hello @Cees-Timmerman,
        I think the simplest solution would be to keep the block comments definition and introduce
        another delimiter with start = # and end = ((EOL))
