    Poor man's t-sql formatter unavailable?
    l formatterpoorman sql t-s
    2 Posts 1 Posters 11.5k Views
    • Gerardo PerezG
      Gerardo Perez
      Hi I used to have the Poor man’s t-sql formatter available in notepad++, using plugin manager it is no longer available, is it unsupported in current versions? or it is and i just have to manually install it?.
      If it enters some bug I wouldnt want to try manually installing it and risking a crash while im editing code.
      • Gerardo PerezG
        Gerardo Perez
        EDIT I must be getting crazy, it showed up once i selected SHOW UNSTABLE plugins, but stability status said good, so i installed, removed, unticked the show UNSTABLE plugins, closed and reopened notepad++ and it was shoing fine in plugin manager, either im getting old or this was a bug in the plugin repository that I cannot seem to repeat lol, anyway, im ok now
