    Find-Replace where Replacing with a Variable Help
    12 Posts 3 Posters 8.8k Views 2 Watching
    • Tony MonroeT Offline
      Tony Monroe
      Hi all. First post on this forum but I need a little help. I’m not entirely sure if this is possible using regular expressions but I thought this would be a good place to ask and, even if it is impossible, point me in the direction of a plugin or tool that could do this.
      Basically I have a text file defining a number of records with different fields like so…
      record1 = {
      | | | | field1: value
      | | | | field2: value
      record2 = {
      … etc
      I want to find every one of a particular field and replace the value based on which record it appears in. For instance, record1.field2 = 1, record2.field2 = 1.1, record3.field2 = 1.2 etc. etc.
      All records are sequential if that makes it easier.
      Failing that, if it was possible to isolate the value and apply a multiplier to it, that will also help.
      I’m not too sure if this is possible using the built-in Find-Replace feature in Notepad++ but I understand it’s a very powerful little tool and there’s a lot in it which I don’t know about. So any help would be appreciated. :)
        Claudia Frank @Tony Monroe
        Hello @Tony-Monroe,
        can we safely assume that the number part of record is increasing by 1 always?
        Is field2 always the name field2 or is it just a reference of being the second field?
        I would assume that a python script can solve this. Assuming that python script plugin will/has be(en) installed.
          Tony Monroe
          Yeah a python script would be a good idea. I’ll need to brush off my python books though. Any good tutorials for using python with Np++ off the top of your head? I only script with Lua really, and first programming language was C, so I kinda skipped python.
          The records aren’t actually named anything different. That was just for the example. So it would have to be based on the line number or order it was found.
            Claudia Frank
            If you are familiar with Lua I would propose you install Lua script plugin,
            which wraps the scintilla a notepad functions. Currently it looks like the download is broken but I assume @dail will fix this soon.
            If python should be used anyway, then I would propose to install the msi and documentation is provided here.
            If there is any question in regards how to use or how to solve, let us know.
            Clauida
            • dailD Offline
              dail
              What exactly is broken?
                Claudia Frank
                Hi dail,
                when trying to download the precompiled plugin you get an access denied message,
                Source can be downloaded.
                • dailD Offline
                  dail
                  Well darn. Might be a few days till I can check into it.
                    Claudia Frank
                    Hi dail and all,
                    it is working - problem was my firefox configuration which doesn’t allow cross site scripting.
                    Once I allowed github-cloud.s3.amazonaws.com, dll could be downloaded. Sorry for confusing.
                      Tony Monroe
                      Well thanks all for the advice. I chose to try scripting it in Python because I’m always keen to learn something new and Python seems nice and easy for such a simple job. Somewhat expectedly my first attempt hasn’t worked. I’m not entirely sure I’m using the functions right and I don’t want anybody to write the script for me but any help pointing me in the right direction would be appreciated. It’s very self-explanatory - the script finds the specified field and changes its value and adding an ‘f’ at the end to indicate a float to the parser. It skips a number of records at the beginning of the file signified by ignore_records, setting those to just initial_value without adding on delta_value. When I run it however, I get a notification saying “Unknown exception” and nothing happens.
                      field = “foo”
                      initial_value = 1
                      delta_value = 0.05
                      ignore_records = 3
                      record_n = 0
                      Editor.gotoLine(0)
                      Editor.searchAnchor()
                      while Editor.gotoPos( Editor.searchNext(0,field) ) != -1
                      record_n += 1
                      if record_n > ignore_records
                      initial_value += delta_value
                      Editor.setSel( Editor.getAnchor + len(field), Editor.getLineEndPosition() )
                      Editor.replaceSel( str(initial_value) + ‘f’ )
                        Claudia Frank
                        The “Unknown exception” error indicates that something went wrong during install of the plugin.
                        Could it be, that you used the plugin manager instead of the msi package?
                        Regarding the script, use the console (Plugins->Python Script->Show console) to get the errors and help.
                        If you type help(name_of_the_function) like help(editor.gotoPos) into the >>> inputbox,
                        you will get additional informations about that function and you can use it to test a particular function.
                        Btw. python is case sensitive.
                          Tony Monroe
                          Thanks all. It’s not very elegant but I got it working. :)
                          field = “foo =”
                          initial_value = 1
                          delta_value = 0.05
                          ignore_records = 3
                          record_n = 0
                          editor.gotoLine(0)
                          editor.searchAnchor()
                          while editor.searchNext(0,field) != -1 :
                          editor.gotoPos( editor.searchNext(0,field) )
                          record_n += 1
                          if record_n > ignore_records :
                          editor.setSel( editor.getAnchor() + len(field), editor.getLineEndPosition(editor.lineFromPosition(editor.getCurrentPos())) )
                          editor.replaceSel( str(initial_value) + ‘f’ )
                            Claudia Frank
                            That’s what it is all about - get it working.
                            One thing which makes me wonder is that record_n doesn’t get reset,
                            so after 3rd run
                            is always true.
                            Btw. if you post code, intend the whole code by 4 spaces then it keeps the layout ;-)
